Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 09-19-2006, 07:38 AM
mrstg65 mrstg65 is offline
Question funny gurgling behind the dash
Hello,
My 93 Olds Cutlass Ciera 3.3 litre 212000 miles auto trans with air has begun making a strange gurgle that sounds like it is just behind the dashboard. It is most noticeable when the engine accelerates. The heat/ac can be on or off but the sound is the same. I could not hear it from outside the car with the hood open. (It will do it even if the car is in park and you rev the engine.) Any thoughts on this?
Thank you!
Old 09-19-2006, 02:14 PM
Bassasasin Bassasasin is offline
Re: funny gurgling behind the dash
Air in your coolant system..
Is there air in your radiator?
Bass
Old 09-20-2006, 08:49 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Bass, that it sounds like air in the cooling system, and it's gurgling through the heater core. The most likely areas for air intrusion is a faulty water pump, loose hose clamp, radiator tank seam, or worst case, head gasket. Also, if you recently replaced any cooling system component (like a t-stat or hose), you need to bleed the system of air.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
