Go Back   Automotive Forums Car Chat > Dodge > Neon | Plymouth Neon > 1st Gen 95-99
Old 09-19-2006, 12:58 AM
_SAi_ _SAi_ is offline
Check Engine Light & Hesitations
Hi,
I have my Check Engine light on (it goes away every couple of days for a bit) and when I get the code it's 12 33 55.
From what I have seen 33 is the A/C Clutch Relay. The symptom I am having is intermittent hesitation while driving. If I put the gas pedal to the floor it runs fine whenever the hesitation occurs.
Does this sound like a sympton of the A/C Clutch Relay? And is this something I should take in to a dealer to have fixed or is this something I could fix on my own (and what is involved)?
Thanks!
Old 09-19-2006, 07:46 AM
das2123 das2123 is offline
Tuning Neons since '97
Send a message via AIM to das2123 Send a message via Yahoo to das2123
Re: Check Engine Light & Hesitations
Is your A/C running while it does this? Does it to it with the A/C off?
2003 Dodge SRT-4
Old 09-19-2006, 08:58 PM
When it does it, it is very noticable with the A/C off. I thought it might not do it with the A/C on so when I had a chance I turned it on and it still did it - although not quite as badly.
Old 09-20-2006, 07:52 AM
Thats interesting....try changing the clutch relay and see if it helps.
2003 Dodge SRT-4
Old 09-20-2006, 05:09 PM
Where is it located? Is it one of the relays in the fuse block?
Old 09-21-2006, 07:54 AM
It's under the hood in the PDC (Power Distribution Center) located right behind the battery. Swap it with your horn relay and honk your horn to see if the relay is good.
2003 Dodge SRT-4
Old 09-21-2006, 05:19 PM
OK,
The Check Engine light went out for about a day. On my way to work this morning it came back on after a couple more hesitations wheil driving.
After work I took the fuse out for the Heater/AC to see if maybe it wouldn't hesitate but it still hesitated.
When I got home I checked the error code again but this time it was 12 21 55. (Oxygen Sensor). Would this problem cause hesitations?
After I read your last response I swaped the AC Realy for the Horn Relay and the horn worked.
Old 09-21-2006, 06:37 PM
So your A/C clutch relay is fine and yes a bad or non-working O2 sensor can cause all sorts of problems. Try to get the "P" code, using a scanner, to get the exact problem. Could be upstream or downstream, but more than likely it's your O2 sensor. Check the plugs and wiring and make sure everything looks OK before spending the money on a new sensor. It's located on the exhaust manifold.
2003 Dodge SRT-4
Old 09-21-2006, 07:09 PM
ricebike ricebike is offline
what year is it? if after 96, OBD II scanner would be best...
clear trouble codes once again & recheck codes later on to see if either 33 or 21 comes back...
Old 09-21-2006, 10:49 PM
95's are OBD II compliant as well, just not fully compliant.
2003 Dodge SRT-4
Old 10-01-2006, 08:18 PM
I got a shop to get the code for me... it's P025. Any thoughts?
Old 10-01-2006, 09:16 PM
umm i think it's missing some #s... should have been a 4-digit one
u know autozone can scan your codes for free, right?
also, i just found out 1st-hand that you can "rent" the tool basically for free if you put a deposit on it...
Old 10-01-2006, 09:22 PM
I had some work done on my brakes and the guy wrote down P025 and said Target idle not reached. Possible misfire bad plugs.
I would just like to confirm this as the plugs and wires were replaced less than 2 years ago.
Old 10-01-2006, 09:37 PM
You should replace your spark plugs every 10,000 miles.
2003 Dodge SRT-4
Old 10-01-2006, 09:45 PM
Does this sound like the spark plugs?
Car randomly hesitates while driving... sometimes a sputter while idling at a light. When it hesitates, the only way to accelerate is to put the gas pedal to the floor. The car doesn't feel like it is going to stall - it just feels like your foot is off the gas.
I'm definately not a car expert by any means. I was wondering if that sounded like a fuel filter problem maybe?
If it was a spark plug problem wouldn't the car want to stall? Or at least still have power - but less power if it was only one plug? The car has no power until I floor the gas pedal.
thx
