Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 09-18-2006, 11:39 PM
buster095 buster095 is offline
2005 impala
I have heat on the passenger side but not the drivers it blows cold any idea?
Old 09-19-2006, 08:45 PM
ysteve ysteve is offline
Re: 2005 impala
Check your climat control. I am sorry but i never heard of that problems. Something wrong with driver side air damper (stuck, switch is short). I think problem ON or IN the dash.
BTW check if you have any "U" or "P" codes
Old 10-03-2006, 09:14 AM
davecarney davecarney is offline
Re: 2005 impala
My '05 is doing the same thing. Any ideas would be greatly appreciated.
Old 10-03-2006, 03:13 PM
adamace1 adamace1 is offline
Re: 2005 impala
I think the steve guy is right, I would think it has to be the switch or more likely the dampener that allows hot or cold air to go through. But i might be wrong. You would need to take apart the dash.
Old 10-05-2006, 03:40 AM
kalanz kalanz is offline
Re: 2005 impala
Hey!
If you have a 2005 you may still be under warranty right? Take it to get serviced.
Old 10-05-2006, 12:34 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 2005 impala
If you have the dual zone heater controls (separate temps sliders for driver and passenger), then it could be an actuator for the driver's side isn't pulling the temp door over. If you have standard single zone A/C (only one temp slider), then you may be low on coolant, or the heater core is partially blocked internally.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-13-2006, 10:46 PM
Joetta Joetta is offline
Re: 2005 impala
I am having same problem with my 05 Impala. Took it to the shop they say it is the contoll switch. Put a new one in myself and it still does not work. looking for problem still
