Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 09-18-2006, 09:01 PM
Namemaker Namemaker is offline
Cold start noise
My 1998 Continental makes a noise during cold starts that sounds somewhat like the starter is not disengaging. The noise lasts a few seconds longer the colder the outside temperature is then disappears unless engine is revved. The noise completely disappears once the engine is warmed up. Thinking it was a starter issue I put a new one on, but it didn't change anything. Then took it to a local mechanic who I trust and also the Lincoln dealer. Both thought it was a vibration (resonance) coming from the power steering line (apparently there is a TSB out about this) and both said the cost to fix it wasn't worth the money unless I couldn't stand the noise.
Has anyone else experienced this? Is there anything else I should consider?
Thanks for any insight you can give.
Old 09-19-2006, 11:17 AM
cougar214 cougar214 is offline
Re: Cold start noise
The sound you are hearing does it sound kinda like a squeel?It could be a loose or worn belt.Possibly a bad bearing on your power steering pump or altinator maybe.The best advise i can give is to check all the simple easy to fix things first.
Typical Low-Speed Vibrations (Less Than 72 km/h [45 mph]):
  • exhaust vibration
  • engine harshness/vibration
  • power steering pump vibrations
  • drive belt vibrations
  • engine cooling fan vibration
  • take-off shudder (excessive CV joint operating angles or bad CV joint)
  • brake roughness or harshness
  • driveline roughness
  • excessive wheel runout
  • tire flat spots
  • components/material trapped between the body and the frame, the engine and the frame or the engine and the body
  • automatic transaxle clutch slippage
Typical High-Speed Vibrations (Above 72 km/h [45 mph]):
  • excessive tire-wheel and brake disc imbalance
  • tire roughness due to high non-uniformity (force variation) or out-of-balance condition
  • excessive tire and wheel runout
  • components/material trapped between the body and the frame, the engine and the frame, or the engine and the body
  • worn suspension components
  • front end accessory vibrations
  • exhaust vibration
  • Power Steering Pump Noisy
  • Low fluid level and possible leakage.
  • REFILL to specified level. REFER to System Bleeding in this section. CHECK for leaks. REPAIR and/or REPLACE as necessary.
  • Plugged reservoir filter.
  • Power steering pump.
  • The Generator is Noisy
  • Loose bolts/brackets.
  • Drive belt.
  • Generator/Pulley.
