Go Back   Automotive Forums Car Chat > Dodge > Durango
Old 09-18-2006, 09:32 PM
DurangoDave DurangoDave is offline
Brake line failure, need your help
You guys have provided some great help here, and I hope I've contributed a bit as well.
Now I need your help.
I have a '99 SLT, 5.2.
I just had the steel brake line that runs the length of the truck corrode through and burst, spraying fluid everywhere and draining the system.
I got an ABS and BRAKE light, of course.
I've replaced the broken line, and am about to refill with fluid and bleed brakes all around.
Question: Will I have to reset the ABS and BRAKE light? If so, how do I do this?
Thanks in advance.
Dave
Westminster, MD USA
Old 09-19-2006, 01:27 PM
Re: Brake line failure, need your help
Okay, problem solved.
After bleeding, both lights have extinguished.
Dave
Westminster, MD USA
Old 03-07-2007, 10:12 PM
rdsciacca rdsciacca is offline
Thanks in advance.
Dave
Westminster, MD USA
Dave I just had my line blow out on 98 SLT 5.9 L in front of passenger side rear tire. Lines look very rusty. Did you do all lines or just splice? Did you use original line routing or make your own path?
Old 03-08-2007, 08:41 AM
rd,
I only replaced the busted line, which in my case was along the driver's side, running the full length of the vehicle. I inspected the rest of the lines, but they looked good.
I bought a full-length piece from the stealership, and it was pre-bent to the proper configuration and with end fittings already installed. I don't see how I could have just spliced in a repair...as you say, it was too rusted to even attempt salvaging any of the line. Had to drop the fuel tank....a real pain.
If you say you have a burst line on the passenger side, then as I recall that's a relatively short piece that just runs from the terminal block near the differential, over to the right rear wheel. I'd just buy a piece from the dealer...actually the price wasn't too bad.
(By the way, I read your Profile.....we have amazingly similar profiles! And my DOB is '48).
Good luck.
Dave
Westminster, MD USA
