Old 09-18-2006, 08:07 PM
phaelax phaelax is offline
control arm bushings
a few months back i had new struts installed, at which point the guy told me I needed new bushings. Someone else mentioned that the bushings might need to be compressed. Is that true? Or is this something I could do myself?
Old 09-19-2006, 08:11 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: control arm bushings
An automotive machine shop will use a press to remove the old bushings and install the new.
Timeslip 08/12/06
AF Community Guidelines
Old 09-19-2006, 10:56 AM
rickisrad rickisrad is offline
Is there a way to press out the bearing with a c-clamp or something like that? I need to put bushings in both of my control arms.
Old 09-19-2006, 11:09 AM
BNaylor's Avatar
You probably won't get enough force using a c-clamp. I did lower control arm bushings on a Camaro Z28 in the past by using a bottle type jack (1.5 ton rating) and using a vice but you have to be careful not to bend any part of the control arm.
Timeslip 08/12/06
Old 09-19-2006, 12:16 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I did the vertical mount front control arm bushings (toward the front of the van) on my wife's mini-van (very similar to the GP) with no problems in my driveway. I didn't replace the horizontal mount bushings (toward the rear of the van) so I'm not sure how difficult they are. I used an air hammer to drive the old ones out and a piece of wood to hold the control arm out away from the frame while removing/installing the bushings. I tapped the new ones in by hand with a hammer. It took longer to jack the van up and take the tire off than it did to actually change the bushings.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
