Old 09-18-2006, 05:38 PM
tanrags tanrags is offline
'93 LeSabre Silly Windows
I have a 93 LeSabre. The driver's window buttons only operate the driver's and the rear right passenger window correctly. It will roll down the front passenger's about 5 inches and stop. The front passenger window operates fine with its own button. The rear left window is inoperative altogether. My parent's 96 LeSabre also has window problems. Help would be appreciated.
Old 09-18-2006, 06:15 PM
Bassasasin Bassasasin is offline
Re: '93 LeSabre Silly Windows
Ive had some problems here.. Took some switches out of a junker. They pop out very easy.. Fixed the inop ones...The sticky ones are a bit more of a problem and proubbly bad travel rails or mechanics.
Good luck
Old 09-18-2006, 06:58 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
As for the passenger side, it could be a motor failing. In addition, for the window switches, you might try this
