Go Back   Automotive Forums Car Chat > BMW > 3 Series
Old 09-18-2006, 04:47 PM
tylerd4 tylerd4 is offline
A/C Making Noise
My 99' 323 is making a noise when I turn the AC on and that noise remains until I turn it off, after a few minutes search engine light turns on and don't go away until the AC is turned off. It also, at times, lose power on uphill and lose the normal pick. Any suggestions?
Old 09-18-2006, 04:55 PM
Gearhead202 Gearhead202 is offline
Re: A/C Making Noise
wat does the noise sound like? that would help out
Old 09-19-2006, 12:52 AM
It is a squealing noise which starts right when I turn the AC on and remains until it is turned off.
Old 10-09-2006, 12:46 PM
crusty_2wn crusty_2wn is offline
Hi, I'm the same problem as well but my car will want to stall when the a/c is on and I'm slowing down. Any ideas?
Old 10-09-2006, 03:02 PM
I am thinking it has something to do with the belts since I haven't changed them since I bought the car, but this is non-technical guessing because on last inspection dealership told me to have 'em changed, but I would like to get a technical opinion from someone who had the same problem than to simply speculate.
Old 10-09-2006, 03:25 PM
Yes you need to replace your belt. I did mine a while ago and the noise stopped, however it starts up when it hasn't run in a day or two then it'll go away....
Old 10-09-2006, 08:56 PM
Bear Bear is offline
On my '90 325ic it was the alternator belt that was loose and I guess the added drag of the compressor set up a silp and squeal. I tightended the alternator belt and the noise went away.
