Old 09-18-2006, 01:13 PM
GASE 95 GASE 95 is offline
slight hesitation 95 SE
1995 grand am SE Quad 4. In the past couple weeks ive noticed a slight hesitation while accelerating but its not every time. In fact its only maybe once a day or once every couple of days. It acts almost like its bogging down for a second or so then picks back up and its fine. It seems to do it most when in low/middle RPM's. I had this problem once before over a year ago and new spark plugs fixed it right up but i have a hard time believing i need new ones already. Could it be clogged fuel injectors or would that cause the hesitation to be more often than once a day? I also just replaced the air filter so i know thats not plugged up.
whatcha think?
Old 09-18-2006, 06:24 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: slight hesitation 95 SE
I would start with the simple stuff, fuel injector cleaner and check your plugs. I had a similar problem with my 95, ended up being the throttle position sensor had a bad spot in it, every now and then it would tell the computer the throttle was closed.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
Old 09-19-2006, 11:43 AM
ok thanks i'll give those a try
