Go Back   Automotive Forums Car Chat > Buick > Regal
Old 09-18-2006, 12:42 PM
blkhwk7 blkhwk7 is offline
Send a message via Yahoo to blkhwk7
Intake Leaking?
I have a coolant leaking problem. I have checked the board & can't seem to find the same problem. When the car is cold & I start it, drive for a couple of miles I smell something burning. Open the hood & I see coolant on the trans on the drivers side of the car. It looks like it might be leaking from the intake under the TB. Funny thing is it seems to have this problem only every other time I drive the car. After a few minutes it stops & everything dries up.
I've seen that this is common with these 3800 motors, car is a 93 with 142K on it. Is replacing the intake gaskets a hard job? I do alot of my own work so I'm pretty mechanical.
are there any links to similar problems that I haven't found on here?
Thx, Jim
Old 09-18-2006, 01:03 PM
maxwedge maxwedge is offline
A990 racer
Re: Intake Leaking?
This may not be the intake could be the TB gasket, check it more carefully the intake manifold gaskets are not usually the problem with this engine.
Old 09-18-2006, 01:34 PM
Re: Intake Leaking?
Does coolant run thru the TB like it does on the LT1 motor?
Or could it be leaking where it bolts to the intake?
Old 09-18-2006, 02:51 PM
A990 racer
Re: Intake Leaking?
On that engine I believe there is coolant in the manifold, any hoses under the tb?
Old 09-18-2006, 05:52 PM
Re: Intake Leaking?
not that I could see, going to try & get to it tomorrow if its not raining
Old 09-18-2006, 06:32 PM
A990 racer
Re: Intake Leaking?
Coolant is present thru the manifold to the throttle body, look closely at the TB gasket.
Old 09-19-2006, 06:34 PM
Re: Intake Leaking?
UPDATE:
changed TB gasket, lower part of old one seem hard, tightened up upr radiator hose, replaced some worn vaccum lines, plugs, wires. Will drive it around tonight to see if the leaks have stopped. had it running & drove around the block didn't see any leaks.
Old 09-19-2006, 06:40 PM
A990 racer
Thumbs up Re: Intake Leaking?
Good news, a lot easier than pulling it apart, thorough diagnosis pays off.
Old 09-19-2006, 06:43 PM
Re: Intake Leaking?
still had to pull off throttle cable brkt, & a heat shield to get the TB off. one nut was a PITA to get to, had to bend a brkt so I could get it off.
Old 09-19-2006, 06:53 PM
A990 racer
Re: Intake Leaking?
Yup, been there.
