Old 09-18-2006, 11:01 AM
jmd445 jmd445 is offline
Synchronizer
I just replaced the camshaft synchronizer assy on my 2001 Taurus V-6 Flex Fuel doing my best to visually align the new with the old. How do I correctly set the camshaft position sensor and what are the spcifications for it?
Also, I have a flex fuel engine, what do the terms Vulcan and DuraTech refer to.
Thanks,
Jim
Old 09-18-2006, 03:41 PM
Johnny Mullet's Avatar
Johnny Mullet Johnny Mullet is offline
Send a message via MSN to Johnny Mullet
Re: Synchronizer
Ford has a special tool to do this procedure.
Old 09-18-2006, 03:47 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Re: Synchronizer
What's with the synchro? Variable valve timing or something for the flex fuel?
Old 09-18-2006, 05:37 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Synchronizer
It's for the ignition system, so the PCM knows which cylinder is on TDC at which time. Since these cars have distributorless ignition, they need some cylinder reference point. At start up, the PCM fires two cylinders simultaneously until it can determine accurately the camshaft position via the CPS/synchronizer.
-Rod
Old 09-18-2006, 08:08 PM
Huney1 Huney1 is offline
Re: Synchronizer
"what do the terms Vulcan and DuraTech refer to.'
In the Taurus, Duratech 24 Valves & dual overhead cams, Vulcan old style 12 Valve with pushrods and one cam.
Lots of engines named Duratech: http://en.wikipedia.org/wiki/Ford_Duratec_engine
http://www.answers.com/Ford%20Vulcan%20engine
Old 09-19-2006, 10:26 AM
wrightz28's Avatar
Re: Synchronizer
-Rod
Right, understood and known, just when I saw "synchronizer" I immediately thought like a manual trans snchro bringing 2 gears to the same speed before engagement. Never heard a cam sensor called that before.
