Hi, I have a 96 contour zetec automatic that I had a broken flex plate on. In the process of diagnosing that, I lost spark and wound up replacing the flex plate, cam pos sensor, crank pos sensor the pcm, and several wiring connectors.No codes, but It took the salvage yard pcm to get it to run. It ran for about a month, now won't run again. No codes, the valve timing is good, fuel pressure good, i'm getting a signal from the crank pos sensor, but the spark timing appears to be about 90 degrees btdc while cranking. Could I have another bad pcm??
Re: 96 zetec Bad pcm again?
Please explain to me how you replaced the camshaft positioning censor on a 96, there isnt one....
-Josh- 96' Integra GSR / ITR cams/valvetrain. Skunk2 IM, Greddy evo2, AEM CAI, RMF Header, Megan testpipe, Hasport mounts, Eibach coilovers, Beaks tie bar, Megan H brace, Rota Attacks, F/R strut bar, Kirk 6 point cage, Bride Cugas, Takata 4 Point, ITR Steering wheel 98' SVT Contour, 3L Port-Matched swap with SVT cams/full bolt ons; 224fwhp. 01' Chevy Blazer, DD. |
Its not very likely that a pcm goes bad, especially two. If it is indeed going bad, youve got bigger issues thats causing it to fail.
![]() "The CEG Nazi" www.contour.org 1996 Ford Contour SE - Sold 3.0L V6 and Arizona Dyno Chip Turbo Kit 364 whp, 410 wtq @ 16 psi and only 4,700 rpms. 1999 Tropic Green SVT Contour - Bone stock and MINT |
Lestro, did you end up with a fix, or is it still messed up? |
Do you know anyone who could do the work for ya if you got the harness? I'm not fond of having the stealership do the work, but 1300 is probably about right for that job, with dealer labor charges and all. They're not jerking you around, but you might want to lean on them a bit and see if your car is covered under the wiring harness recall bulletin. Mine is just out of the time frame (100k miles or 10 years, whichever is first) but you should push them to see if you are covered still, since yours is a 96. Eh, make some noise about it. Here's the link to the recall: http://www.contour.org/FAQ/recall/99M03/ Part numbers and labor times, plus diagrams are all on that page. The worst thing they can do is say no. If you are still covered, lean on them HARD. Otherwise, is the car worth it to you? They're not bad cars, Ford just screwed up on these models. People who get the wiring done are happy with it. You should cruise over to the Contour forum and read up on these cars and the fixes. www.contour.org |
http://www.contour.org/ceg-vb/showthread.php?t=304
