Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-18-2006, 08:14 AM
badbob52 badbob52 is offline
92 Bonney Radiator problem
Yesterday, while the wife is out on errands, the water temp gauge redlines to 280. She got it home, I opened the hood and steam is blowing out the top right side of the radiator. Appears to coming out of a threaded brass connection right below the radiator hose.
Is that a pressure release valve that can be replaced or should I be thinking of replacing the radiator, considering it's got 130K miles on it.
Would like some advice before I have the car towed to my repair shop.
TIA,
Bob
Old 09-20-2006, 08:04 AM
manlystanley manlystanley is offline
Re: 92 Bonney Radiator problem
Check out the thermostat. If it never turns on the coolant will only cycle inside of the engine.
Does your fans turn on? I beleive the fans are controlled by a different sensor though.
Old 09-20-2006, 08:53 AM
Thanks for the reply, but I've already gotten the car into the shop. Turns out there was a huge crack in the radiator, and I had to replace it along with hoses, thermosat, gaskets etc . Ended up costing about $600.
