Old 09-18-2006, 01:02 AM
Vortecblazer Vortecblazer is offline
1997 s10/zr2 trans. problem
the problem i am having is, when i put my truck in drive, it is already in 3rd gear.. and takes off in 3rd gear, it doesn't shift on its own, but if i manually shift it to 2nd gear, it will go to second.. but when i shift it to 1st it stays in 2nd and if i shift from 3rd to OD it stays in 3rd? it makes it extremely hard to pick up speed, taking off in 3rd gear..
Old 09-18-2006, 02:14 PM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Re: 1997 s10/zr2 trans. problem
Ignition switch module will cause this.
BIG TIME problem with the 1997's.
1995 Factory Blazer Service Manual for sale, PM if interested.
Old 09-18-2006, 11:06 PM
i guess that might explain the other problem that i am having, my key is stuck in the ignition... is that all the same problem?
Old 09-18-2006, 11:16 PM
BlazerLT's Avatar
AF -Advisor
Could be.
But the ignition switch is not the key tumbler.
It is the black mudule in the bottom of the steering column.
Old 09-19-2006, 08:35 AM
Macgyver007's Avatar
Macgyver007 Macgyver007 is offline
Send a message via MSN to Macgyver007
there is what I guess you could call a push rod, that runs from the tumbler to the ign switch. Had the same prob with mine. ONly takes about 20 mins to replace including the time to take all the under dash plastic off.
The Tumbler is another story, MAKE SURE YOU ARE CAREFUL with the Yellow wire in the Colume or the ABS will blow.
I love these trucks !!
I have had an 84 and 89 Pickup X-cab P/U also assorted 2 Dr Blazers.
I now own a 97 4 Dr.
Still a work in progress but ...
http://www.cardomain.com/memberpage/761008
Macgyver
Ontario, Canada
Old 09-19-2006, 02:51 PM
alright guys, thanks for all the help. i have been wondering how to fix this for some time.
