Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-18-2006, 12:37 AM
aleekat aleekat is offline
Gurgling Dash
96 Ram, 1500 4x4. I have read all over the net. Trucks normally gurgles in the dash at first start up. I have pulled the rad cap and parked on an incline suspecting air in the heater core/cooling system. Put heater on max, and let it run for about 20mins. Have done this a couple times, but the noise wont go away. Any guesses/tips?
Old 09-19-2006, 08:07 AM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: Gurgling Dash
If the cooling system is full, you can try cleaning the radiator cap on both sides of the gasket and the center piece...I think it's a check valve. If that quiets down the gurgling, buy a new cap as the old one will start back leaking air soon and gurgling the coolant overflow jug.
Old 10-02-2006, 07:50 PM
1thunder 1thunder is offline
Re: Gurgling Dash
head gasket blown letting compression into the cooling system??
Old 10-04-2006, 05:34 PM
Re: Gurgling Dash
No symptoms of head gasket issue. No pressure in overflow tank, no sweet exhaust smell. No loss of power/acceleration etc.
Thought I got it fixed, relized replaced the cap 6months ago, and auto parts guys convinced me to get the "lever-vent" cap. Replaced the cap with a new one. Still gurgles, but not as much...
Old 10-12-2006, 04:23 PM
cleanshavenrsx cleanshavenrsx is offline
Send a message via AIM to cleanshavenrsx Send a message via MSN to cleanshavenrsx
Re: Gurgling Dash
possibly intake gaskets
Old 10-27-2006, 09:48 PM
csl97 csl97 is offline
Re: Gurgling Dash
Air in the cooling system. Get the passenger side up in the air take off cap and let it run until you don't get anymore air bubbles
Old 10-31-2006, 10:22 PM
Re: Gurgling Dash
Have done it. Steep incline on driveway.. Done this 4-5 times. Still gurgles, but only when driving away, no gurgle in park/idle..
Old 11-04-2006, 09:32 AM
clutch492 clutch492 is offline
ASE Master Tech
Re: Gurgling Dash
I have the same issue. Nothing to worry about. It has to do with the location of the heater core. Air can get trapped in the core. When you first start the truck, this air purges out, causing this noise.
Old 11-04-2006, 07:27 PM
Re: Gurgling Dash
Was just curious why after 10yrs, it just started..
Old 11-05-2006, 12:12 AM
ASE Master Tech
Cool Re: Gurgling Dash
After your reply, I did some thinking.
I did have one occurance that may have started this same trouble on my pickup.
The impeller on the water pump rusted away completely. All that was left of the impeller was a star-shaped piece of metal.
After replacing the water pump, I noticed this gurgling sound that you are talking about.
Every 6 months (or so) I am having to back flush the heater core to remove the metal particles that were once the water pump impeller.
This restriction in the heater core could be what is causing the noises. After I run it for a little while (5 minutes) it goes away.
Try back flushing the heater core. Try to catch what comes out of it. If there is a lot of rusty crap, I will bet you have the same situation developing. My truck did not overheat or anything. Try the back flush and get back to me. I am now very curious if your water pump impeller is rusted away like mine was.
