Old 09-17-2006, 11:37 PM
Young Chuck D's Avatar
Young Chuck D Young Chuck D is offline
Send a message via AIM to Young Chuck D
in the process of finding the cause for my engine to be running on 3 cylinders.
last nite very suddenly my car started chugging and shaking and started sounding like a lawnmower. i pull over, pop the hood and find a spark plug wire loose. push it back down and it changes nothing. so i drive home and checked all my plugs today (bosch platinum +4's) and they're in beautiful condition. so my dad comes out and tells me to start it up. i do. he then pulls a spark plug wire and the engine begins to struggle. puts it back and it runs the way it was before. pulls another plug (the second from the left facing the front of the car) and nothing changes. from this he concludes that i'm running on 3 cylinders. he suggested new spark plug wires and began to look for the distributor. realizing its behind the engine under the intake manifold he began cursing american cars and went back in the house.
will new plug wires fix my problem? something tells me its more complicated than that.
1999 Chevrolet Monte Carlo LS [semi-daily driver until LIM repair or trade-in for '13 Fusion, 110k miles]
Gone but not forgotten:
1995 Pontiac Grand Prix GTP[sold, 128k miles]
1996 Oldsmobile Cutlass Supreme SL Coupe [a minivan tore my door off, totaled, 84k miles]
1998 BMW M3 Hardtop Convertible [a pathfinder armada stopped in front of me, totaled, 70k miles]
1989 Chevrolet Cavalier Coupe [died, 160k miles, engine problems]
1990 Hyundai Excel GL [died, 220k miles, died]
Old 09-18-2006, 11:08 AM
Ryan066 Ryan066 is offline
Re: in the process of finding the cause for my engine to be running on 3 cylinders.
well from what i belive its not the spark plug wires,, do those cars have coils? anyways your problem is what the other end of the spark plugs into..
u can check plug wires by measuring resistance,, they should all be around the same.
if absoulty nothing changes once u take that certain wire off then its not the wire,,, if it changes it slighty then maybe it is the wire
Old 09-18-2006, 08:40 PM
Cold_Silence's Avatar
Cold_Silence Cold_Silence is offline
Send a message via AIM to Cold_Silence Send a message via MSN to Cold_Silence
Mine was doing the same thing after i hosed it down under the hood, [not doing that again.] I found a cracked plug where the insulator is, it was causing a short that i could SEE at night, a spark wud hop from the plug to the closest piece of metal. Soo i just got new plugs and wires and it fixed it, its prolly time for new ones anyways so try that out.
The New Ride!! 2002 Cavalier Coupe..
Originally Posted by noshun
It's a lovely 2200, but got about as much poke as my grandma with no fingers.
www.cleanstartsolutions.com
Old 09-19-2006, 09:57 PM
you, my friend, are correct.
but i have new plugs in there already so i just bought wires.
i have plat. 4's
Old 09-19-2006, 10:36 PM
Classicrocjunkie's Avatar
Classicrocjunkie Classicrocjunkie is offline
Lifted GMT-360!
Send a message via AIM to Classicrocjunkie
Originally Posted by Young Chuck D
i have plat. 4's
Thats your problem right there....4 prongs are just a gimmic and acutally do more harm than good. 2 is even pushing it. Our cars do not like BOSCH products for some reason, along with most GM cars in General. In fact i had a customer come back to my work today after telling him it was a bad move to install their Bank 1 O2 sensors because they are pure junk and he was getting a CEL from it even being brand new. He got a new Delco from the dealership and his problems went away. He personally thanked me for my help. Look at my waste of 159 bucks for the Nology hot wires... Just another gimmic. Stick with AC delco plugs if your not boosted. They will work the best.
Please don't PM me with your J-body Issues. Post appropriately in the forums,
and I will toss my opinion in your thread if I have anything to help. - Thanks!
2006 Chevrolet Trailblazer
2010 Glastron GT 205XL
Old 09-20-2006, 07:51 AM
i replaced the plugs all at once, why would only 1 cause problems? and they're still all in good condition. are you saying bosch is a silent killer of gm engines? that sounds semi-preposterous.
i just plugged the 1 new wire though and it hasn't changed anything, now i gotta risk it driving to school like this. ugh.
Old 09-20-2006, 02:33 PM
i am now looking into replacing a coil pack. hopefully i'm not dropping quarters in a dry wishing well.
also i noticed a bit of oil on the plug in the bad cylinder (cylinder #2)
someone said a piston ring could be my problem. :fear:
as the day marches on i will attempt to update this
Old 09-20-2006, 05:10 PM
coil pack will fix the problem, but make sure its the right one... i think u can test em when they are out,, make sure they HAVE resistance with an ohmmeter
Old 09-23-2006, 07:34 PM
i dunno what the hell ur talking about, the coil with the bad cylinder(#2) connected to it was the bad one. i changed it, back to normal, everybody is happy and can ask me for rides again.
Old 09-23-2006, 08:16 PM
quake61's Avatar
quake61 quake61 is offline
hell before this cavy i had a stratus and installed bosch
even the auto parts guy told me they were crap and ended up selling me the oem plugs
car worked fine after that before was missfiring a cylinder
cavys r the same gm dont like bosch in any masking and in any shape
Old 09-24-2006, 01:00 PM
u must be dumb then.. there was two coils correct? i said make sure you replace the right one meaning the ones thats shorted out causing the problem rather then the one that is fine. then i said you can test them by measuring the resistance but i guess thats over your head..
try and take some advice from people you ignorant cunt
