Go Back   Automotive Forums Car Chat > Mercedes-Benz > E-Class
Old 09-17-2006, 11:54 PM
RicardoARod RicardoARod is offline
2002 E55 Rear Clunking noise
hello i have this 2002 E55 that has a rear clunking noise like it from the suspension, but everything is tight and all is. does anyone know about any TSB's that are out for that or has experianced the same problem and solved it? any help is much appreciated thank in advance
Old 09-19-2006, 09:38 PM
deiseldwarf deiseldwarf is offline
Re: 2002 E55 Rear Clunking noise
My wise teacher usually puts the vehicle on it's wheels and bounces the thing, to hear if it makes noise. If it does, a buddy can listen, as you bounce and you might find that noise. Futhermore, you could also use a rubber mallet and hit the bushings, to hear if they clunk. SOmetimes that is the way to make those little gremlin noises show themselves.
I would like to know if the clunk manifests during accelleration, turns, or whatever circumstance. That my lead you to better explore the source of the noise.
Old 09-19-2006, 10:41 PM
it sounds like the spring is pinging durring bumps but at time it does it as you stop
Old 09-23-2006, 01:10 AM
So, this car uses a shock and coil spring set up? If so, have you inspected the spring, in case it has broken?
Old 09-23-2006, 12:12 PM
arlingtoncountyred arlingtoncountyred is offline
Check the rear shocks, common problem on the W210 chassis.
Old 09-26-2006, 09:30 AM
joe_h joe_h is offline
well i dunno about rear but i had that kind of problem before and i had to change, i dunno what they call 'em but i think its the shock absorbers, the metal that take the "beating"......have run down a generous bump or something made the car clash down hard?
