Go Back   Automotive Forums Car Chat > Nissan > General Discussion
Old 09-17-2006, 09:42 PM
todd200sx-ser todd200sx-ser is offline
Paper towel stuck in a bad spot
In a nutshell, after replacing my valve cover gasket and spark plug seals because of oil I found on my spark plugs, I decided to stick some paper towel on a long stick down the tube to mop it up before I put the plugs back in. As you've probably guessed, a small wad of paper towel is now stuck down there out of sight.
I'm not sure if it will burn up or what, I'm scared to turn on the car. So far I'm thinking I can either turn on the car or pay a mechanic to get it out. I'm not sure how to even get in there to the cylinders. Anyone have a thought (besides how dumb an idea that was)?
car is a 96 Nissan 200sx se-r
Old 09-17-2006, 09:47 PM
Broke_as_****'s Avatar
Broke_as_**** Broke_as_**** is offline
Re: Paper towel stuck in a bad spot
By out of sight do you mean in the cylinder or just stuck down in the hole the spark plugs sit in?
1989 240SX Fastback. . . . . . . . . . . . . . . . . . . . . . . . . . . 1995 300ZX Twin Turbo
Warning: Objects in mirror aren't as fast as they thought they were.
Old 09-17-2006, 09:49 PM
As far as I know it's stuck in the hole the spark plugs sit in. It is past the point where the threads are, and has seemed to turn a corner.
Old 09-17-2006, 10:20 PM
So it's in the cylinder then...well, I would get a flashlight and see if there is any part of it you can grab with a pair of pliers or something. Bit of stick with a hook on the end, vaccuum...something. I actually don't know how bad it would be to try and start it with it in there but I can't see it making anything explode. Like you proposed it would probably get burnt and crushed then exit cylinder. But it may cause some misfiring.
Old 09-17-2006, 10:41 PM
I started the car up. It idle'ed low for a few seconds then seemed to be fine...drove it around a bit too. Glad it wasn't serious. Thanks for your reply
