Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-17-2006, 09:19 PM
rimfire,22 rimfire,22 is offline
Is there a better way?
Hello to all,
On my 89' Camry the indicator on the dash is lite indicating a rear bulb is out again. When one has no one to look back there while pressing on the brake pedal is their a better way to check? I wonder if the 3rd brake light bulb is out? Any pointers?
rimfire,22
Old 09-17-2006, 09:47 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Is there a better way?
Back it close to a building, one with a big glass window would be best, and hit the brakes. Watch the reflection in the window. Though not as clear you could use any wall. You might have to step outside the car and reach in with your foot to see it.
Old 09-17-2006, 10:17 PM
JOET/CAMRY JOET/CAMRY is offline
Thumbs up Re: Is there a better way?
Hello rimfire22 and RIP,
another way to check if their is a burned out brake light when you have no one to hold the brake pedal down is to get a pipe or broomstick or something similar; cut it to the proper length (if necessary) so you can place it between the brake peddal and the drivers seat. adjust the drivers seat if needed. done.
Regards,
JOET/CAMRY
Old 09-18-2006, 02:36 AM
KimMG KimMG is offline
AF - Advisor
I just put my back pack against the brake pedal to check my brake lights. Just need to move the pedal enough to release the plunger on the brake light switch, don't need to press the pedal enough to stop the car.
Old 09-18-2006, 09:54 AM
Hello to all,
Yeah I already tried those suggestions and so far as I can tell no brakes lights seem to be burnt out! I know it must be something. Even the 3rd brake light is fine. What a perplexing problem.
rimfire,22
Old 09-18-2006, 01:48 PM
idmetro idmetro is offline
Check out this previous post http://www.automotiveforums.com/vbul...d.php?t=609573 it might have your answer.
Old 09-18-2006, 03:05 PM
idmetro,
Thanks for your swift response. I'll start looking/checking out the light sockets and see what happens. If I can't find anything a trip to Toyota may be more handier.
rimfire,22
