Old 08-30-2002, 04:19 PM
NuEra's Avatar
NuEra NuEra is offline
Banned
Question How to wire switch?
This is a simple question, but what kind of switch do I need to wire a LED. I went to Radioshack and they had switches with 2 or 3 prongs in the back and different amp amount allowaces. What do I need? Its just a wire coming from power to the switch to the LED, and then grounded. I got this correct?
Old 08-30-2002, 04:32 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
All you need is a SPST (Single Pole, Single Throw) switch. If you're just wiring one LED, you only need a little one.
And your wiring is correct. Wire from + battery to switch lead. Wire from other switch lead to LED anode. Wire from LED cathode to ground...
However, you should put a current limiting resistor in the circuit somewhere. A 400 ohm (or thereabouts) 1/4 Watt resistor should do the trick.
Old 08-30-2002, 04:43 PM
93speed's Avatar
93speed 93speed is offline
What kind of LED are we talking about? Windshield washer lights or just a regular radio shack plain LED? If you're wiring a specially made vehicle accessory, you probably won't need the resistor. If you have a plain LED, you will run into the use of a resistor.
Old 08-30-2002, 05:20 PM
NuEra's Avatar
Banned
its just a plain LED, I know it matters what side of the LED but what about the switch?, Does it matter which side the powers coming from? Should I put the resistor before the switch or the LED? thanks again
Old 08-30-2002, 06:11 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
it's normal procedure to wire the switch between the battery and the LED .... to guard against shorts
Old 08-30-2002, 06:32 PM
ci5ic's Avatar
Switches do not have any polarity, so you can wire it up on either side. Shouldn't matter where you put the resistor as long as it's in series with the switch and the LED. No matter where it's at in the circuit, it's function will remain the same.
Personally, I would solder the resistor to the LED's anode (+). There's not polarity on resistors either. Then, run wires from the batt. to the switch, to the other lead of the resistor, and from the cathode (-) of the LED to ground.
