how to get wide tire look?
i currently have 285/75/16 nitto terragrapplers on my 2000 silverado.
i have aftermarket rims i believe they are 8 inches wide. do i have to buy 10 inch wide rims to go wider? |
Re: how to get wide tire look?
Pancake!
![]() ![]() ![]() "When I step on the gas, I want people to think the world is coming to an end!" - Homer Simpson 2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster |
You answered your own question. I wouldn't get depending on how tall of a wheel you get i wouldn't get any wider than 9" in the front.
*Under Construction - New sig to debut* |
Do you need wide tires or do you want tires that are wider than the fenders?
If you just want the tires to stick out beyond the fenders, then you can just buy rims that are more offset, to push the tires further out. With the factory rims the lug holes are set all the way on the outside portion of the rim, but you can buy them set more towards the inside so more tire will stick out beyond the fender. |
305/70/16 widest on stock stock rims, 4wd w/o hitting or rubbing.
if you changed the offset thats out the window. |
