Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 09-17-2006, 07:59 PM
ned032002's Avatar
ned032002 ned032002 is offline
How to turn on Fog Lights
My buddy has a 96 Intrepid and he can't find the knob/switch to turn on the fog lights. The manual shows that if you pull out on the head lights knob then they'll turn on but they don't. Is there a special trick that turns them on? Any help would be appreciated.
Old 09-18-2006, 07:19 PM
ned032002's Avatar
Re: How to turn on Fog Lights
I guess nobody in here has any idea what the problem is, so nobody in here has fog lights I'm assuming?
Old 09-19-2006, 09:45 PM
yapper70 yapper70 is offline
After you turn on the lights (turn the switch to the right) you should be able to pull out on the switch and the lights come on. Just as you posted. If they dont, check to see if the lights are still good, if still no light check for bad wires or no ground.
Old 10-01-2006, 04:07 PM
ned032002's Avatar
But if you pull the "switch" then the knob comes off. I'm sure it's not suppose to so whats the problem here. This should be easy to answer if you have ever used your fog lights.
Old 10-03-2006, 01:43 PM
Yes I actually use them most of the time. The switch will pull out once you have the knob turned all the way to the right. You cant run the fog lights without the regular lights on. If it wont pull out easily the switch may be damaged, if that is the case I have seen replacement switched on e-bay for about $10.
Old 10-03-2006, 07:30 PM
ned032002's Avatar
No the switch pulls literally off the dash, into my hand. So heres what happens, I turn the knob clock wise to turn the lights on and then pull out on the knob once the headlights are on and what happens, the knob comes off the dash and into my hand. and the fog lights do not come on.
Old 10-04-2006, 04:35 PM
That would tell me that the switch is damaged. I have seen these on e-bay for about $10 and will take about 15 minutes to replace.
Old 10-04-2006, 07:01 PM
ned032002's Avatar
Ok thank you for your help.
Old 10-04-2006, 07:18 PM
I've seen a while back a modification that can be done to allow the fog lights to be on whenever the parking lights are on. I believe it was on www.dodgeintrepid.net but I'm not sure. I cant find it now. If I find it I will post a link to it here.
