Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 09-17-2006, 07:52 PM
dozer 9 dozer 9 is offline
01 camry timing belt
mine is bad,rotor will not spin. what are the steps or secrets in changing this out? What is the water pump and seals and some springs that I have read about, do you suggest in changing these also? thanks in advance
Old 09-17-2006, 08:08 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 01 camry timing belt
What engine is in the vehicle?
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 09-18-2006, 03:38 PM
2.0 4-cylinder
Old 09-18-2006, 06:42 PM
Brian R.'s Avatar
Resident Chemist
If you are going to do the repairs, make sure you can remove the crank pulley bolt before you do anything. Either bring it to a shop with an air wrench and ask them to loosen it for you, then tighten it temporarily until you get home, or put a breaker bar on it with the end of the wrench against the ground facing the front of the car and give the starter a bump.
I suggest you change the water pump and the crank and cam front seals also. While you have the front dissassembled, check the various parts as outlined in the Maintenance Manual and replace as necessary.
