Old 09-17-2006, 07:42 PM
Sargento69 Sargento69 is offline
Send a message via MSN to Sargento69
Very Frustrated!!
i have a 91 crx si with a b20. My problem is that when i am driving the steering wheel starts to shake quiet a bit. It does this when i hit like 30mph to about 55mph then it becomes a very small shake. When the steering wheel is shaking and i press on the brake pedal the steering wheel shakes even harder.. I thought is was the front tires. so i put my pair of slicks i have and it does the same thing.. I since replaced the old rotors and brake pads. I put slotted and drilled rotors with ceramic pads. and guess what??? it still did the same thing.!!! I know that it might be the tie rods but they check out fine. Has anyone had the same problem???
When i bought the car the previous owner had replaced the wheel bearings. Could it be that they installed them wrong?? After i replaced the rotors, now that i go to press on the brake pedal. It feels that its goes up and down alot. As if the rotors had warped.. Any suggestions are greatly appreciated!!!
Well thanks for the help!!!
°Sä®GëNTö69°
B20B POWERED '91CRX SI
Old 09-17-2006, 08:05 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: Very Frustrated!!
If not a suspension component, are you sure you cleaned bend the rotor well, it could be on crooked..
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-18-2006, 12:22 AM
TheSilentChamber's Avatar
TheSilentChamber TheSilentChamber is offline
Forunn Daberator
Have you gotten an alignment?
Old 09-18-2006, 01:33 AM
hondacivic99sivtec's Avatar
hondacivic99sivtec hondacivic99sivtec is offline
Send a message via Yahoo to hondacivic99sivtec
alignment +1
-tony-
2000 honda s2000
Old 09-18-2006, 01:51 AM
Jetts's Avatar
Jetts Jetts is offline
Send a message via AIM to Jetts
allignment also sounds like warped rotors
BRET
11/07/87 - 11/11/04
*** KEITH VALLEE***
R.I.P
Keith. higher then any mother fucker out there..... R.I.P homie..
Old 09-19-2006, 11:15 AM
C8H18Blood's Avatar
C8H18Blood C8H18Blood is offline
No no, this is probably what happend to me. My drive shafts were warped somehow (not straight) and the more power I gave it and the faster I went (usually over 30mph/ 1st gear too) the steering wheel and pretty much whole front end shaked rediculously. I took it to my mechanic and after we discovered the shaft was the issue, he swaped out the shaft (only driver side) with another used B16A shaft, problem solved. So check out that angle, cause from what you describe, it sounds exactly like that.
Cardomain.com Page
Old 09-19-2006, 05:27 PM
Hybrid1990crx's Avatar
alignment -1.
sounds like your wheels are out of balance.
Old 09-19-2006, 06:57 PM
dagoEF's Avatar
dagoEF dagoEF is offline
I had something like this happen when I changed brakes on this girl's car, She had wore the rotors so bad they couldn't turn them. Got new ones and it shook like hell on one side... long story short, she had warper the actual hub. Junkyard gave me a complete spindle, slapped it on, no more vibration.
Old 09-24-2006, 09:16 PM
Well after taking it to shop, they told me it was the rack and pinion. (i think thats how its spelled..lol) so now i have to go to a junk yard and find me a decent looking one. Plus i think its a good idea to get new inner and outer tie rods for it. Thankfully i have another car to drive, the si is going to sit in the garage for a while. Thanks for your input!!!
°Sä®GëNTö69°
Old 09-25-2006, 07:22 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
if you change the rack, you'll need an alignment for sure... you should still check your axles, and take the rotors in to get the lateral runout checked... look at rims, both for balance and for bends, check tires for abnormal wear, it's seldom just one thing that's making your vehicle shake... check all those things, techs at sears can do it in like 45 mins... so even w/o any real knowledge, you should be able to do it in like 1.5 hrs lol
I know, that's not saying much for sears techs.. but I used to work there.. most of them spend their days in the back smoking and drinking coffee. :P
Old 09-26-2006, 09:26 PM
C8H18Blood's Avatar
You could get Quaife's shortened rack and pinion, make it really nimble! Thatd be cool.. I know you wont, I'm just jabberin
Cardomain.com Page
Old 09-27-2006, 07:22 AM
Forunn Daberator
Its not shortend, its quicker ratio, or shorter ratio. And it doenst make it more nimble, it just reduces the amount of lock to lock turn.
Old 09-27-2006, 10:16 PM
what he said. technically is like taking a bike with a 44t sprocket, and 16t flywheel and replacing the 44t with a 54 tooth, it will take less rotation to spin the rear wheel.
Old 09-27-2006, 10:19 PM
C8H18Blood's Avatar
Ok, but I ment more nimble because you can steer the steering wheel less distance, and turns the wheels more than stock. I.e, more nimble with driver input, more responsive change in direction..
Cardomain.com Page
Old 09-27-2006, 10:21 PM
have you ever driven a car with a short ratio rack and pinion? they get squirrly at high speeds, not exactly something you'd want for a daily.
