Go Back   Automotive Forums Car Chat > Toyota > 4Runner/GX470
Old 09-17-2006, 02:28 PM
d_smeltz60 d_smeltz60 is offline
93 4-Runner Rear Axle Leak @ Axle-Wheel Junction
Hi,
I have a '93 4-Runner and there is oil leaking at the junction where the rear axle and the wheel come together on the drivers side. I pulled off the wheel and the brake drum to see if the oil had reached the brake and there is no oil on the brake. I have an estimate to replace the axle shaft seal and it will cost $200.
I have Hanes and Chilton repair manuals. The Hanes manual shows that the axleshaft complete with the brake assembly can be pulled out from the rear axle without disturbing the differential assembly after the differential is drained, brake line disconnected and brake backing plate mounting nuts removed. A rear axle adaptor and slide hammer may be needed to remove the rear axle assembly. The Chilton manual shows that the brake needs to be disassembled before the axle can be pulled. Does any one know which is the correct method for the '93 4-Runner? Also, it looks like the axle shaft oil seal and a gasket need to be replaced, are these the correct replacement parts? Is the axle shaft oil seal press fit onto the axle? Can I do this job myself?
Thanks,
Deb
Old 09-17-2006, 05:13 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 93 4-Runner Rear Axle Leak @ Axle-Wheel Junction
From the '93 Pick-Up/4Runner manual stickied at the top of this forum:
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Brian R.'s Avatar
Resident Chemist
Old 09-17-2006, 05:14 PM
Brian R.'s Avatar
Resident Chemist
Brian R.'s Avatar
Resident Chemist
Old 09-17-2006, 05:36 PM
Brian R.'s Avatar
Resident Chemist
Brake assembly is removed without dissassembly (see above).
You need inner and outer oil seals, a snap ring, and a backing plate O-ring. Remember to bleed the brakes (brake fluid). Also, don't breath the brake dust. Disturb it as little as possible. Don't blow on the brakes. If you want to clean out the brakes, take the shoes off and spray the area (not the shoes) with brake cleaner. Regrease the pivot points and the adjuster.
The oil seals are press-fit, but you can drive them in with a large socket or a piece of pipe (smooth flat edge), and a hammer. You should bring the bearing, axle and backing plate to a machine shop (Pep Boys?) to have them press them together.
Old 09-18-2006, 06:27 PM
Brian,
Thanks for all of the schematic drawings, the procedure and the list of parts that will be needed. It was much easier to understand viewing the schematics you sent. What manual did your schematics come from and where can I get a copy of that manual?
I will let you know how things turn out.
Thanks,
Deb
Old 09-18-2006, 07:11 PM
Brian R.'s Avatar
Resident Chemist
Here's the sticky post containing the manuals:
http://www.automotiveforums.com/vbul...d.php?t=510646
Manual for your truck:
http://personal.utulsa.edu/~nathan-buchanan/93fsm/
Download it and print whatever you want. Keep it handy...
Old 09-22-2006, 08:03 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
It sounds like the inner axle seal, and is easy to do.
You don't need to do all the stuff in the pics above.
After the truck is on jack stands and the wheel removed:
1. drain diff
2. disconnect and pinch off brake line and parking brake cable.
3. remove the 4 bolts on the back that hold the axle shaft on the housing
4. pull out the axle shaft/brake assy out
5. pull out the seal and replace
6. reassemble in reverse order.
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
