Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 09-17-2006, 02:20 PM
silverado122775's Avatar
silverado122775 silverado122775 is offline
Loud Brakes
Everytime I would brake the pedal and sterling would shake really bad, so replaced the Front Rotors and Brakes (purchased parts from autozone). Now when I drive the car there is a noise comming from the brakes all the time, even when I am not using the brakes. This noise is very loud and not so much a high squel like what a bus would make, but a lower pitch still very loud, almost like a door squeek but constant. When I step on the brakes it stops very good, and there is no shaking in the wheel or pedal. I did notice when after my test drive the brakes started to smoke. Is that normal? I thought is was.
Any body have any idea what it could be or did I do something wrong?
FYI: there is no adjuster valve from what I can see either.
2000 Silverado Z71, 5.3L, K&N GenII Air Intake, Y-pipe Exhaust (no muffler), Bosch Platnium +4 plugs, 242k miles and still running.
Old 09-17-2006, 11:45 PM
Cat Fuzz Cat Fuzz is offline
Re: Loud Brakes
Smoking brakes is never a good thing. I'm going to assume you're talking about the front brakes here. Sounds like you have some stuck calipers. Replace 'em.
Old 09-19-2006, 01:47 AM
sierrap615 sierrap615 is offline
Master Tech Wanna-be
Re: Loud Brakes
did you lube the slide pins?
Daily driver: 1995 Buick Regal Custom 3.8L 4T60-E 150K miles
Gone: 1994 Saturn SL2 1.9L MP3 168,666 miles
EPA 608 Universal Certification
EPA 609 Certification
Old 09-19-2006, 08:20 AM
Re: Loud Brakes
The slide pins? Are those the pins that hold the braket in place for the outside pads? They are threaded pins. if so, I did not. I will try to lube them up and see what happens. I was also told to take sand paper and rough up the pads a little bit too.
Old 09-19-2006, 09:57 PM
Re: Loud Brakes
the pins are maybe two inches long, majority of which is not threaded, maybe 1/2inch is threaded. use brake lube on the non-threaded part only.
Old 09-27-2006, 08:55 AM
Re: Loud Brakes
Well I found what the problem was. On the brakes themselves was a clip that was sticking out and rubbing against the wheel. It did not look like it was used for anything on my setup. So I snapped them off. and now.. it sounds and works great!!!
Old 10-05-2006, 12:59 PM
saturnspeed_12's Avatar
saturnspeed_12 saturnspeed_12 is offline
Re: Loud Brakes
i bet the smoking was from the chemicals on the rotors. if cleaned really good, it wont happen. but using the brakes for the first time can cause smoke. after that, then id be worried.
Ian
Saturn Tuners Club-OH Chapter President
1993 Saturn SC2 rebuild project for dad
1995 Saturn SL2 current daily driver /w a lot of work
2007 Chevy Cobalt injen cai, full lsj exhaust, dc sports fsb, progress springs and rear sway bar, enkei wheels/hankook rubber --*boost in progress
Old 10-05-2006, 01:01 PM
Re: Loud Brakes
Could have been. It does sound like I may need to tackle the rear brakes too
Old 10-05-2006, 01:04 PM
Re: Loud Brakes
rears are easy, as long as the drum plays nice. 2 taps with BFH and it should come right off.
Ian
Old 10-06-2006, 08:11 AM
Re: Loud Brakes
Thanks
