Go Back   Automotive Forums .com Car Chat > Nissan > Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail
Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail Nissans greatest 4WDs and SUVs
Old 09-17-2006, 10:59 AM   #1
rav4t
What to lube
Hi just wondering what i can lube to stop squeeking in my suspension on my 02 xterra I had my shocks changed a 1 yr ago but the leaves spings or something sqeeks what can i do?
rav4t is offline   Reply With Quote
Old 09-17-2006, 02:50 PM   #2
OffroadX
Send a message via AIM to OffroadX
Re: What to lube
Not much you can do. Jack up by the frame to fully droop the suspension and open the leaves a bit, then blast high-pressure water in between the leaves to get crud out. Maybe spray some very light grease in, but it won't last too long.
Or if it's up front, try some silicone spray on the control arm bushings.
When did you last check your spare tire's pressure?
OffroadX is offline   Reply With Quote
Old 09-17-2006, 07:10 PM   #3
Schludwiller
XTerra Guy
Schludwiller's Avatar
Re: What to lube
I find the more people try and quiet their leaf springs, the more noise they make. High-pressure water between the leaves has kept mine mostly quiet. Lubricants tend to attract dirt, which is what you want to avoid.
Xterra4x4.com and the Xterra Offroad Webring
Schludwiller is offline   Reply With Quote
Old 09-26-2006, 01:04 AM   #4
bluztraveler
bluztraveler's Avatar
Re: What to lube
I had bigger teflon pads put onto the end of my leafs, when I had the extra leafs put in. Never had a problem, but yea you need to spray them out real good after hitting the mud.
Rutt Nutts Offroad
bluztraveler is offline   Reply With Quote
