Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-17-2006, 07:58 AM
97gs-t teamrtv 97gs-t teamrtv is offline
Send a message via AIM to 97gs-t teamrtv Send a message via MSN to 97gs-t teamrtv Send a message via Yahoo to 97gs-t teamrtv
Valve Cover Question
I took out my Valve Cover to get powdercoated about 2 weeks back. I covered the remaining block with an old towel and sheet for lack of anything better that i had. When i covered it everything was clean with a coat of oil on the cams. I took the towel off yesterday and I see surface rust on the cams. The car sits outside with a cover. Is this anything to worry about and will it go away when the car is started or should i worry about wiping away the rust and trying to clean it before i put the valve cover back on? Sorry mods, not sure which section this belongs.
97 gs-t: Guages: boost, oil pressure and temp, water temp and volts. AEM cam gears, short throw shifter, hks ssqv, injen intake, brembo drilled rotors, akebono ceramic pads, sportline springs & koni ajustables, Strut bars: front, rear and lower rear tie bar. Evo III manifold and o2, megan downpipe, Apexi N1 catback, 16g, 190 fuel pump and FMIC.
Old 09-17-2006, 08:05 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Valve Cover Question
I would think its ok to run. Its probably just like your rotors get when they set for a rainy day and then you go out the next day and they are rusty.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-17-2006, 08:50 AM
ned032002's Avatar
ned032002 ned032002 is offline
I wouldn't worry about it unless it's been sitting that way for a really long time.
