Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-17-2006, 02:22 AM
firestarter69 firestarter69 is offline
Unhappy Oil pressure
So yesterday My engine started shaking everytime I pressed on the gas, and I noticed that my oil pressure guage was lower than usual. I pulled over to check, no leaks and no freaking oil in the engine either!!! I put on a new filter and mobil1 oil. But every time I slow down the oil pressure guage slowly drops to 0%. When I speed up it goes back up.
Old 09-17-2006, 03:13 AM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: Oil pressure
Sounds like your oil pump could be going bad... Where did all the oil go the first time? Did it just burn it all out and you hadn't checked it for a while?... Also, does it loose pressure when you start it and let it idle? If so, let it idle and pop your hood and take the oil fill cap off and see if your motor is slinging oil around in the head. If so your sending unit on the bottom of the oil filter housing is bad. But if its not slinging any oil around then shut it off immediately and don't drive it until you get it fixed... I would say make sure its not the sending unit gone bad, then I would check the oil pump. But it sounds like its not getting any oil at all and is indeed the oil pump.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-17-2006, 07:02 PM
Re: Oil pressure
Fing thing. Well I'll do it tommorrow. But any ideas on the cost of a new oil pump? Or how hard that is to R/R?
Old 09-17-2006, 07:30 PM
ricebike ricebike is offline
Re: Oil pressure
year/ engine size/ 2WD or 4WD? automatic? stick?
um, there's a free chilton/haynes type manual online on www.autozone.com repair info section... just enter the vehicle 1st, then goto that link to see what it entails, since I dunno your car & your past mechanical abilities...
Old 09-17-2006, 07:39 PM
Re: Oil pressure
Ok lets get something straight here. Its not gonna matter if its 2wd, 4wd, auto, or stick because we aren't talking about the drivetrain here. We are talking about his motor not having oil pressure...
The cost of a new oil pump is gonna vary to wherever you decide to get it from. Personally though, I wouldn't go and get some cheap off brand oil pump considering the importance of oil to the motor.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-17-2006, 08:24 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: Oil pressure
Type of vehicle and engine make all the differance in the world if you have to remove the oil pan. 2wd-4wd can make a differance in some cases. Cooler lines from an auto trans might cause an insignificant annoyance. Is your oil pump on the bottom of your engine inside the oil pan or on the front of the crankshaft? In either case oil pumps don't wear out. You may have a broken pressure relief valve spring that regulates oil pressure. The relief valve is often part of the oil pump. Replace the spring with a new one. Or buy a new pump that has a new spring.
Old 09-17-2006, 08:30 PM
Re: Oil pressure
Our pumps are in the oil filter housings... And I didn't say anything about engine size not mattering. Just drivetrain things don't matter on our cars in this subject matter.
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-17-2006, 09:02 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Oil pressure
You need to fill it up with oil and put a manual test oil pressure gauge on it.
No oil and low oil pressure could be a bad leaking oil sending unit.
As said look for oil leaks and if the engine has no or low pressure with a manual test gauge the look at oil pump.
MT
MT
Old 09-17-2006, 09:13 PM
Re: Oil pressure
He hasn't confirmed yet if it has a leak or if he just let the motor burn out all his oil... It doesn't take long with these cars if its getting up there in mileage and you give it about 2 weeks without checking it...
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-21-2006, 01:11 PM
Re: Oil pressure
Well I checked it today. Oil is squirting around. So my car is making a last ditch effort for me not to kill it. I'm gonna go buy the sensor to see if that fixes it. Thanks for your guys help.
Old 09-21-2006, 01:36 PM
Re: Oil pressure
So it sounds like you do have oil pressure, the gauge just isn't reading it. Like I suggested before the sending unit is just bad then... Keep an eye on the oil though. I am still curious as to where it all went before when you had none in it... Do you check your oil on a regular basis then or not?
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 09-21-2006, 06:34 PM
Re: Oil pressure
I checked it every week or 2. I found theres a difference between a oil pressure guage and oil pressure switch. Their both on the oil pump housing. It was the oil guage unit.
Old 09-22-2006, 12:19 AM
Re: Oil pressure
+1 for me. lol
-Brian
  • 92 Firebird sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 14 Silverado 1500
  • 26 Equinox RS
