Old 09-17-2006, 01:46 AM
malletslinger's Avatar
malletslinger malletslinger is offline
Unhappy 3rd gen door pins...
I bought a new door pin for my drivers door on my 89 many months ago, but after I bought it, I took a good hard look at how it is set up and stuck that now pin in what I thought would be the best place for it...my tool box
Im REALLY not looking foreword to this task...Can anyone give me some pointers to make this a little less painful...
When I look at the way this is set up, and I think about how heavy this door is, it makes me want to, oh I dont know, ____________(insert something thoroughly unpleasant here)
There has got to be a better way than just muscling through this.
Feel free to wow me with a revolutionary new way to face this fear...
Old 09-17-2006, 07:36 PM
Morley Morley is offline
Re: 3rd gen door pins...
Support the door on the end with it open. Use either a jack or engine hoist. You'll need the tool for compressing the door spring to reinstall it. Remove the spring, beat the pin up and out. Mark the outline of the body side of the hinge and then remove the 3 bolts holding the body side of the hinge on. You'll have to lift the outer end of the door and move it around to get the body side hinge half out. Once it is out, replace the bushings in it and then reinstall it. Make sure to get it in the same position it was in before you removed it. Line up the pin holes and drive the pin in place, making sure the head is completely seated. Next put the door spring in the compressor tool and reinstall it.
Hint.....you'll invent new curse words doing this job, it is a real pain.
Old 09-17-2006, 09:21 PM
Thanks. Now that I have a plan of attack, maybe I can finally force my self to get this done...maybe
Old 09-17-2006, 11:36 PM
Nate355RS's Avatar
Nate355RS Nate355RS is offline
I had the same problem with my old camaro about a year ago. I thought it was a pretty easy job myself, all you have to do is pull out your wallet and give someone about 40 bucks and let them do all the frustrating work for you
'91 RS, forged LT1, GTP heads, blower cam, AFR Hydra-Rev kit, ram air intake, SLP 1 3/4 headers and 3" y-pipe, 3" Dynomax exaust, Yank 2800 TT stall converter, Strange 3.73 gears with Zexel-Torsen LSD, ect, ect...
Old 09-19-2006, 09:17 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
il do em for 30
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
