Old 09-16-2006, 08:38 PM
Dyno247365's Avatar
Dyno247365 Dyno247365 is offline
Rezing the Iroc? Not me
My dad calls me up today to tell me that my mom's brand new civic's powesteering pump already went. *laughs* I thought it was frickin funny. He also told me that he drained the tranny fluid in the Iroc and it was red. Joy? Not yet, but the transmission may still be salvageable. He's going to change the fluid and take it for a test drive. If he can fix the car, that's great! But if he can't that means it's the engine because it did the same thing with both transmissions. Not my problem right now. Thank you God.
1996 Dodge Ram 1500 5.2L 5spd!!!
1987 Chevy Iroc-Z- -Needs a new cat
1992 Nissan 240sx 5spd- SOLD
Old 09-17-2006, 09:10 PM
Dyno247365's Avatar
Re: Rezing the Iroc? Not me
UPDATE, It's still broken.
Old 09-17-2006, 09:21 PM
666_speed's Avatar
666_speed 666_speed is offline
Son of Satan
:/ not good.
Old 09-17-2006, 10:36 PM
Dyno247365's Avatar
I just don't understand why both transmissions went. It must have been with the way I set it up, whether not the right amount of fluid in the pan or tc, or it was the throttle cable not adjusted, but it really pisses me off when i think about it. That's why I said I wouldn't mind another third gen but not this one.
Old 09-17-2006, 10:45 PM
97cavalier's Avatar
97cavalier 97cavalier is offline
since you stuck all this money in it, just take it to a tranny shop and have it done right, just have it all rebuilt fresh so you KNOW what it has ben through.
95 Z71 Silverado 4x4 ext. cab
Mods- Flowmaster Exhaust,Intake
Old 09-17-2006, 11:51 PM
Morley Morley is offline
If you take it to a trans shop, don't talk about a rebuild just yet. Ask them to have a look at the governor, the gear on it is plastic
Old 09-18-2006, 08:03 AM
scoobytuff scoobytuff is offline
When it goes back in make sure the tv cable or the kickdown cable is adjusted like it should be. If it's not it will fry the transmission. That could have been what caused failure of the other trans.
Old 09-18-2006, 09:46 AM
Dyno247365's Avatar
Okay, and replying to the others, I did tell my dad to have an expert look at it now since we don't want to really mess it up.
Old 09-18-2006, 10:36 AM
88camaroproject's Avatar
88camaroproject 88camaroproject is offline
Send a message via AIM to 88camaroproject
are you sure because my tv cable is blocked off. not hooked up to anything. there actually isnt a cable. it seems to work fine. except for the big trans leak out the bottom of the dipstick. but that sucks about the car, i guess it would be a good idea to have an expert check it out.
87 firebird formula ws6
(currently has a old 78 305 with the following upgrades,
including lots of miles and stock heads and internals....oops)
crane cam cam specs
performance valve springs and retainers, flowtech headers, 255 lph fuel pump,
holley 600cfm carb, weiand single plane manifold, a healty diet.
14.90 1/4 mile....just wait for the 406 to be finished
MY VIDEOS
MY PICTURES
-Tom
Old 09-18-2006, 11:08 AM
bag91's Avatar
bag91 bag91 is offline
Yup I agree, I was so frekin tripped out about touchin that thing when I put the B&M in.......
91 RS Camaro V8 305 TBI
cold/ram 14"/3" open element
K/N filter
3.73's
B&M Megashifter
180 thermostat
Flowtech TERMINATOR Exhaust
3" exhaust cutout
Silvania Silverstar Headlights
Ronal R15 Firehawk Wheels
Hankook Ventus Sport (front)
Sumitomo HTR+ (rear)
275/40ZR 17 all around...
_____________________________
Old 09-18-2006, 11:44 AM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Yes, the TV cable controls line pressure to work with the throttle position. If it's too loose or not hooked up, line pressures will be too low and the clutch packs will eat it. One way to determine if the TV setting is too loose is the presence of a condition known as "short shifting" or "stack shifting". This is where the transmission goes through the gears fast, usually into 3rd gear before 15MPH. If this is occuring on your transmission, get that cable on there.
Only the TH200/C, 2004R and 700R4 have TV cables - if your car has a TH350, it will have a detent cable which controls part- and full-throttle downshifts, but does not have any other affect on the transmission.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 09-18-2006, 06:50 PM
oh ok cool cuz i have a th 350. scared me for a second
crane cam cam specs
MY VIDEOS
MY PICTURES
-Tom
Old 09-18-2006, 09:23 PM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
i think you have a lemon, so sell me the parts i need!
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
