Old 09-16-2006, 09:14 PM
hunter666 hunter666 is offline
1990 buick lasaber not starting
I have 1990 buick lasaber,3.8 liter,new plugs ,water pump ,thermostat,error code reads 15,bad radiator?? but the real prob is the car starts fine in the morning then constantly floods out,have to put pedal to metal to start then she blows black smoke till excess gas burned off,then runs at very high idel,starts to overheat engine till i shut it off,wait for 1 hour start again same thing happens,,does anyone have any ideas,Thank you
Old 09-16-2006, 09:56 PM
sferguson sferguson is offline
Re: 1990 buick lasaber not starting
I would start by checking the fuel pressure regulator, sounds like it may be holding to much gas in the injection system. I recently purchased a guage at Harbor Freight at 14.99.
Old 09-16-2006, 10:25 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Luckily, for those interested, the fuel pressure test kit at Harbor Freight, is on sale for $7.99, until the end of Sept.
Be sure to check the TPS for proper operation. You might also want to investigate the CTS, (Coolant temperature sensor) function.
Engine should not overheat even at high idle! Are you sure it is overheating, or does just the gauge indicate overheating? Do you have any boil over into the coolant reservoir?
Old 09-17-2006, 12:48 AM
Alibi's Avatar
Alibi Alibi is offline
Send a message via Yahoo to Alibi
I second that you look into replacing the CTS. It is located near the IAC (Idle air control valve) on the throttle body. Tis be a small round brass-colored plug with an electrical harnes on it. A bit of a PITA to get at, but is inexpensive to replace.
While you've got that section pulled apart, you might as well give this a shot: http://www.lesabret.com/phpBB/viewtopic.php?t=4054
The idle problems might be as simple as a plugged pintle on the IAC.
Any other codes other than code 15? (heres how if you don't know otherwise: http://www.lesabret.com/phpBB/viewtopic.php?t=1201).
-Eric
89 LeSabre T-Type: CAI, STB, F41 Suspension, Moog Ball joints and tie rods, dual-out flowmaster and dual tips, Pointiac CD HU, Delco type 2 Ignition, etc.
Basic H/C body info:http://www.3800power.bravehost.com/index.htm
http://www.cardomain.com/ride/2318168
Old 09-17-2006, 02:48 PM
they say that sometimes the answer is quite simple,well for my erratic idel problem that was tormenting me for 1 week, I decided to clean the trottle body,lo and behold,runs fine idels fine,guess i should look for the simple things first,thank you guys for your time and all were vere informative
