Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-16-2006, 08:14 PM
goatman794 goatman794 is offline
Talking rear defroster
i have a 1999 mercury grand marquis and the rear defroster does not work i checked the fuses and relay and all are fine. i check the rear electrical termainals and found a voltage of 13.5 so i know its powered to the rear terminals. i also check the continuity on the strips that run through the glass and they appear ok. the defroster was working some in the past but now there is nothing.. ????? any thoughts of what else i could do??? thnaks steve
Old 09-18-2006, 08:41 PM
vtwindave vtwindave is offline
Re: rear defroster
check to make sure that you have a good ground connected to the rear window strips. if you don't have a ground connected the strips will not heat.
