Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 09-16-2006, 07:12 PM
NateS's Avatar
NateS NateS is offline
Send a message via AIM to NateS
Cracked head????
Okay, so I finished up my head gasket swap. Everything is fine and running. All of the problems have been taken care of as you can see my other threads. HOWEVER, my car still overheats. It only overheats during long pulls like 2nd-4th or highway cruising. The car will cool down very quickly though when I let off the gas or even take it out of gear and let it drift. This is exactly what it did before. My compression checks out great and the oil and coolant are fine. I really doubt my headgasket has a problem seeings how I just replaced it and there are no sypmtoms of a blown HG. I bought a new thermostat, drained and replaced the coolant and the oil. I was thinking about getting a coolant flush done. As of now I am going to bet that my head is cracked or warped. Any thing I can do to see if it is really warped or cracked other than removing the head and pressure checking it? Could something else be causing this overheating problem?
On a side note my stock head came today from gstclips and it looks great! I am taking it to the shop sometime this week to start the slow long build process. If my head on the car is cracked it is really not that big of a deal because the new head will be done in about 3 months or so and I can take it easy on the car for now. If this overheating problem is something else though I would love to fix it. Thanks for any help.
95 GSX 5 speed
2.3L stroker bored .020 over
Built head
Bullseye/Borg Warner T04B 57 Trim Turbo
RNR 3" turboback w/ o2 eliminator
255 lph Extreme Motorsports fuel pump
Extreme Motorsports mbc
SAFC
Greddy Type S BOV
FMIC (core 28x10.5x3.5)
FIC 650cc fuel injectors
RK Sport Fuel Pressure Regulator
My Car Domain
Old 09-17-2006, 10:56 AM
xavier3jr's Avatar
xavier3jr xavier3jr is offline
Send a message via AIM to xavier3jr Send a message via MSN to xavier3jr
Re: Cracked head????
you didnt get the head shaved or anything before you put it back on?
96 GS - 5 Speed-Sold
1998 Ford F-150 XLT 4X4
Old 09-17-2006, 11:02 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
It would be best to run a block check head gasket chemical test on it and see if it is getting any exhaust in the coolant.
Most good repair shops can run the test and it takes the gueese work out of it.
Here is the tool they use.
http://tools.batauto.com/index.php?c...on=show_detail
MT
MT
Old 09-17-2006, 12:36 PM
NateS's Avatar
Yeah a buddy of mine told me about the chemical tester he has. I might try to borrow it from him one day this week and test it. Thanks guys.
95 GSX 5 speed
Built head
SAFC
Greddy Type S BOV
My Car Domain
Old 09-17-2006, 05:59 PM
MT-2500's Avatar
AF - Advisor
Good if you have a buddy that has one.
They are a little trickie to use.
But the take the guess work out of head gasket/head leak or not.
If the test fluid turns yellow you have exhaust leaking into coolant system.
There should be instructions with tester.
You need to get your coolant level down some so you do not suck the coolant into tester.
If you do dump te test fluid out of tester and put new in.
Also test when engine is good an hot.
Indication of head gasket leakage is heating up fast on a load.
And a bad leak will block heater heat flow as it blocks coolant flow and causes a fast heat up.
Good luck on your testing and let us know how it goes.
MT
MT
