Old 09-16-2006, 06:04 PM
paker paker is offline
Front Strut Cartridge Replacement
97 Lumina 3.1L
I got the special tool from AutoZone. The 24mm socket fits the stem nut. Next step is what I am trying to figure out. Is it just jamming a Torx50 bit between the 24mm socket wall and the stem? Thanks.
Old 09-16-2006, 07:19 PM
maxwedge maxwedge is offline
A990 racer
Re: Front Strut Cartridge Replacement
The torx fits into the top of the strut stud to hold it from turning as the socket or box wrench turns the 15/16 nut.
Old 09-17-2006, 11:53 PM
I still fail to see how the torx bit holds the stem from spinning. The stem top does not have recess that matches the torx bit. The stem top is just flat.
I gave up and used an air impact wrench. It worked well. Thanks.
Old 09-18-2006, 08:34 AM
A990 racer
For what it is worth the oe cartridges on my 97 Lum. had the torx socket on the end, many aftermarket do not. Good they were'nt rusted together.
Old 09-18-2006, 09:48 AM
Thank you for solving the mystery of the torx bit for me. Yes, OEM cartridge was replaced at 60K miles. Now it has 130K miles. I hope this will last through the remaining life of the vehicle. Just in case, I will put a drop of oil on the stem thread. Thanks.
