Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-16-2006, 04:59 PM
DaSarge DaSarge is offline
Tail Light Assembly - 98
Can anyon direct me to a diagram or instructions for disassembling the interior to get access to the right rea tail light assembly in a '98 Suburban?
Thanks!
Old 09-17-2006, 11:06 AM
777stickman 777stickman is offline
Re: Tail Light Assembly - 98
Thanks!
Open the rear doors or tailgate. Look for 2 black rubber plugs just inside the pillar. Remove those plugs and remove the screws holding the light assy in place. Then the assy will rotate out at the rear. The weather stripping will hold it in place so use caution when trying to pry the assy loose..........Steve
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 09-17-2006, 06:08 PM
Steve:
Thank you most kindly. I'm a little sheepish I didn't figure this out myself, so thanks again.
Old 09-17-2006, 06:55 PM
OK, smooth a silk. Thank you, Steve, yet again.
It occurs to me that -- quite by accident -- I had the right tool: a long screw driver that was both magnetized and had a flashlight built in. It might have been a pain without this.
There is no gasket covering the screw holes & the screws are a bit rusty. Is there supposed to be a gasket?
The dealer gave me only two bulbs; I used what appeared to be a good bulb from the old assembly. It all checks out, so here's hoping.
Thanks again for this great resourse.
Old 09-18-2006, 10:07 AM
You're very welcome and glad I was able to help you. My '98 sub has the rubber plugs so I assume they should be there if only to fill the holes........Steve
57 Chevy 210
