Go Back   Automotive Forums Car Chat > Jaguar > XJ6| XJ8| XJ12 | XJR
XJ6| XJ8| XJ12 | XJR Classic and Current XJ Models, including the R series.
Old 09-16-2006, 04:58 PM
slideways...'s Avatar
slideways... slideways... is offline
xj coolant question
i had a 98 xj8 come in to my shop the other day and the coolant was a milky white color...does anyone know what this is about? i thought all jags used OEM orange coolant. ive never seen this before and no one i talked to has either. does anybody know about this? it seemed like it had a waxy residue, and was kind of the color of water and flour mixed...
Rice Police #1. dont argue with me just because you are a riceboy and/or have sand in your vagina. i am superior. and i am smarter than you. end of story.
Old 09-16-2006, 06:27 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: xj coolant question
Sounds like it could be cooling system suppliment. It is basicly water soluble oil. Napa used to have Mac's 13. My quick search didn't find it. Have you seen that same color and consistecy of stuff used by machinist to cool and wash as parts are worked on? I doubt that the coolant is recommended by any manufacture. The owner probably knows better than the entire SAE and wouldn't consider any other formula. This could be the same product that makes identicle claims of being a waterpump lubricant.
http://www.barsproducts.com/product.cfm?id=42
Old 09-16-2006, 06:46 PM
With that supplement, would you know if their is any wax or parifin? The cap on the pressure resivoir was coated with almost a half inch thick build up of a waxy substance. Their was also lots of chunks of that waxy substance floating in the coolant. We tested the strength of it, and it showed good to -34 degrees fairenheight. The owner has no knowledge of any substance being added to the cooling system.
Old 09-16-2006, 07:26 PM
This barsLeak has the same words anti-rust and waterpump lubricant. I guess it might not hurt anything. Who needs their waterpump seal and thermostat lubricated?
Evidently the Jag has anti-freeze in the cooling system.
I have read some threads about permenant anti-freeze doing something similar to the parifin with pictures of partialy blocked water passages.
I would recommend flushing and refilling yet be concerned that it might be blamed for the next failure. No doubt something is about to go wrong with every 98 Jag.
Old 09-17-2006, 10:42 AM
ok thanks for the help. i looked into it a little bit further and supposedly its just an additive you can add to water to basically make it into coolant. seems kind of useful and bad at the same time, as in its cheap and easy, but sounds like it wouldnt have the rust inhibitors and stuff coolant has and also if the wax would collect and clog the rad. passages. anyways thanks
Old 04-10-2007, 01:32 PM
Bauer104 Bauer104 is offline
It could also be the water pump blades. The original water pumps had ceramic parts which disintergrated eventually causing the water to turn white.
Old 07-26-2008, 01:36 AM
djagman djagman is offline
i am surprised it took this long.jaguar had a undocumented tsb on the coolant.it will actualy gel in the system.flush it good!!! and install mbz approved coolant and all will be well.promise.ps check the tstat housing and if plastice upgrade to aluminum from xks.com 80.00!!
Old 07-26-2008, 01:41 AM
'97ventureowner's Avatar
'97ventureowner '97ventureowner is offline
Please check the date of the last post in the thread and do not respond if that date is longer than 3 months from the current date.
From AF's Community Guidelines:
POSTING IN CLOSED OR OUTDATED THREADS:
If a thread has been closed, there is probably a logical reason for it. If you feel that the reason(s) for closure of the original thread are unjustified or wish further clarification feel free to contact any member of the moderating team. However, do not start a new thread about another closed thread.
Please avoid posting or voting in outdated threads. It merely clutters up the message board and makes it more difficult for fellow members to sort through the vast amount of information contained on the boards. If you have new and important information to add regarding a past discussion, feel free to start a new thread and if need be, add a link to the original thread.
The link to these guidelines can be found here:http://www.automotiveforums.com/vbul...uidelines.html
Closed.
Thought for the Day… Alcohol does not make you fat - It makes you lean... against tables, chairs, floors, walls and ugly people.
If a prostitute here in America loses her job to a prostitute in India , is that considered "outwhoring"??-Jay Leno
" A Good Thing To Know"
