Old 08-30-2002, 10:19 AM
shocky shocky is offline
Send a message via ICQ to shocky Send a message via MSN to shocky
Lightbulb Question about fuel pressure modifier ...
Hello, yesterday i install my brand new fuel pressure modifier, and it allows pressure adjustments from 25 to 60 psi, and i want to know how many PSI do i have to adjust to daily use and for a RACE.
thanks for your help.
:flash:
94 Acura Integra 4 Door, JDM Si-R II B16A 5.4Million Series Engine Swap (170HP Stock), With CTR Camshafts, STR Camgears, Clutch Masters Stage 4, DC Sport Ceramic Header 4-2-1, Exhaust System 2.25" W/Apex-i N1 Cat-Back, AEM Cold Air Intake, ECU Erick Racing 5,800rpm Vtec, B&M Fuel Pressure Regulator, Y21 Code GearBox, 16" Rims W/Yokohama Avs Sports. It's not much but I still can smoke fools. Oh Yeah and Don't forget, I'm Proud Member of Guatemala Streetracing. http://www.gtstreetracing.com
Old 08-30-2002, 10:38 PM
Tominos Tominos is offline
doesn't the instructions come with a formula on how much fuel pressure to raise depending on what mods you have from stock. for example, if you have intake header exhaust you'd probably raise your fuel pressure 6-7 psi for a 4 cyl engine. it depends how much air flow you have increased to your engine. just ask the co. you bought the fuel pressure regulator from and they will figure it out for you.
Old 09-01-2002, 08:46 PM
88_SC_CRX_Si 88_SC_CRX_Si is offline
The plugs will have the final say, on where the fuel pressure will end up at. Pick-up some Anti-Seize and put it on the plugs (if you have not already). That way you can pull them, while the engine/head is still hot. Without worrying about pulling the threads out of the head, along with the plug(s). Also, try not to let it idle, that will start cleaning the plugs, and giving you semi false reading...
In most cases, the MAP sensor "should" see more air is passing through the intake. It then will tell the ECU to adjust the injector pulse width accordingly. Sooo, trying raise the fuel pressure is really not necessary.
The ECU has the fuel, timing, ect... maps/tables, and the MAP, PA, IAT sensors. To figure out the best injector pulse width. To send out at any given engine load, and weather condition....
"Noth'in like Induction..."
88' CRX Si - JRSC @ 6psi Z6 Mini-Me, JDM SiR Conversion
NOS #5122, JR Liquid InterCooling System
ZYDNE SECU, 450's
B&M FP Set, B&M Command Flo
AutoMeter - Phantom FP, A/F, N2O, Boost gauges & pods,
ARP HSKit, AEM Pads, 87' HF Drums, DYI CAI
Old 09-02-2002, 11:08 PM
VelocityTrends VelocityTrends is offline
Banned
Stock Pressure is 35lbs bumping it up to 45 is fine for daily driving or race! Now if your going to run N2O ever..... bump it up to like 55lbs or even 60lbs depending on the shot!
www.velocitytrends.com
Old 03-24-2004, 06:36 PM
crabby760 crabby760 is offline
if i have a stock b16a motor with intake/header/exhaust and i just add the aem fuel pressure regulator and bump up the psi say 10 or 15 would that even produce more power ????
Oil Pressure 130 Pounds Smith1000 Park Avenue 10 04-18-2011 08:39 PM
