Old 08-30-2002, 06:53 AM
bobbyd bobbyd is offline
My car is finally lowered! I have questions!
Finihsed up lowering my ride last night. I used coil overs and have it almost as low as it will go. My front tires do this / \ Will an alignment fix this problem? Thanks!
"Are you gonna bark all day little doggy, or are you gonna bite?"
Old 08-30-2002, 07:15 AM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Lowering
When the top of your wheels tilt in like that it's called negative camber. No an alignment will not fix the camber. You will need to get a camber kit to correct that. I would go ahead and get an alignmnet done now to make sure that the toe is okay but i would get an camber kit soon before you eat up your tires. After you get a camber kit on go and get an alignment again.
Old 08-30-2002, 07:27 AM
are camber kits hard to install?
Old 08-30-2002, 08:11 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
Hey whats up,
I just had my camber and alignment done about 2 weeks ago. I bought the Ingalls kit for the front. First of all, let me say that you need to know what height you are gonna drive your ride so you can set the camber and alignment at that height. So, maybe you need to drive it like it is for a lil while and make sure it is what you want where it is.
Second of all, it cost me $123 to get my kit installed, camber adjusted and aligment done on top of the $80 or so for the kit...and you thought you got a good deal on coil overs. SURPRISE!! It's not cheap to alter suspension, correctly. Anyway, that's my input. Make sure you get a kit with good adjustment, ex: +/- 3 degrees.
Old 08-30-2002, 10:00 AM
darolh darolh is offline
Nobody has mentioned this but you need to do the rear too. It will have to have the toe set also.
Old 08-30-2002, 11:07 AM
mdnnccivicrcr mdnnccivicrcr is offline
what about if your front camber is messed up but you are still sporting a stock suspsension? I've done no mods to my suspension but my camber is bad messed up.
Old 08-30-2002, 12:53 PM
QuickSilverEF9 QuickSilverEF9 is offline
Send a message via AIM to QuickSilverEF9
Next time research before doing the project .... What shocks and struts did you use?
1997 Golf GTI VR6
-Leather Interior
-47000 miles
-JVC KDSH707 Head Unit
ON THE WAY
-2xInfinity Kappa Perfect 6.1 components
-12" Polk Momo sub
-JBL 600.1 amp
Future
-Brock B2 deep dish wheels
-Suspension.....
Old 08-30-2002, 01:16 PM
i knew that it was going to happen but i just wanted to know if an alignment would fix it. this was not my first dropped car just my first drop this low. i can always raise it up if needed but this is my beater car. i used drop zone coil overs with kyb shocks.
Old 08-30-2002, 01:17 PM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...camber's your friend you can have your car dumped w/o the wheels smackin into the fenders w/o negative camber
SOLD!
Old 08-30-2002, 01:25 PM
true to the camber being your friend. i can turn still, i guess that is a good point. nice drawing of a car in your avatar thing too. looks sweet. what is that? a hb?
Old 08-30-2002, 01:26 PM
marked001's Avatar
Moderadur
I dunno..I stole it from somewhere hehe..
SOLD!
Old 08-30-2002, 02:05 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Yea, mine are beginning to tilt inward, but it isnt too bad.
I am running all stock suspension.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-30-2002, 02:21 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
If your wheels have a bad tilt you could have busted ball joints. Jack the car up and see if the wheels are shaky. If so you need new Upper Control Arms.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 08-30-2002, 02:26 PM
BigBearWest's Avatar
BigBearWest BigBearWest is offline
WWW.CalgarysFinest.COM
Send a message via ICQ to BigBearWest Send a message via AIM to BigBearWest Send a message via MSN to BigBearWest
what is a good drop? before u have to get a camber kits?
Old 08-30-2002, 02:31 PM
Anything less than 2'' and you don't NEED a kit, but you should still get one to prevent uneven wear.
