Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-15-2006, 09:30 PM
winke1952 winke1952 is offline
Exclamation 2002 Barvada won't start HELP!!!!!!!
This Bravada has been in the shop numerous times in the past for this problem. First they thought it was the neutral saftey switch (replaced). Drove for a few days and bam it does it again. Towed back to the shop and they can't find the problem...they towed it to a dealer and the dealer replaced the starter relay. We have drove it for awhile now and it has times that it didn't want to start, but messing with it for awhile and it started. This time the wife was stuck at work and it won't start. It's like the lights are on and no one is home...All the electrical light up and works but, it won't turn over at all. Hope someone has some kind of a idea what might be wrong. I have owned many Oldsmobiles and the main problem I've found was the computer goes haywire. I beginning to think this might be another one. But, the cost of replacing it is very high.
Old 09-15-2006, 10:25 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
Re: 2002 Barvada won't start HELP!!!!!!!
Does your Bravada have a remote starter or security system on it?
Old 09-16-2006, 02:23 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
what exactly is it doing or not doing when you try to start it? Is it cranking then dying or what???
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 09-16-2006, 06:31 PM
No remote start...yes on security
Old 09-16-2006, 06:36 PM
It does nothing at all...everything works other then it won't turn over. I did replace the starter relay today but, that didn't help.
Old 09-16-2006, 08:05 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Kinda sounds like a bad starter/solenoid contacts doesn't it?
I had to replace the whole starter recently on my '97.
Old 09-18-2006, 08:09 PM
Well, then you'll have to go some digging. Take apart the bottom of your dash and find the starter wire (usually bign yellow or purple wire) Check to see if it gets 12v when cranking. Also, check the ignition wires too (usually pink and white wires) to see that they keep 12v when cranking. Dont worry about the accessory wires.
If that checks out then you'll have to get under the car to the starter itself and do the same check. Once you do that, come back here and report what you find.
Pioneer 4900mp
Orion C63 Coax rear
Old 09-18-2006, 08:40 PM
ericn1300's Avatar
AF Premium User
could be the security system, i had a no start situation caused by the pass key security system that i bypassed for under a buck in parts. so much for security. check out this site:
http://www.motorage.com/motorage/dat...key%20II%22%22
