Old 09-15-2006, 03:01 PM
tgrudzin tgrudzin is offline
Turn signal switch
Left turn signal fails to turn off when the steering wheel returns to center. Parts store quotes switch at $87.00. Is it really that expensive? Or are they looking at the wrong part?
Old 09-15-2006, 03:03 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Turn signal switch
It's probably because the multifunction switch handles everything from lights to signals to wipers; it's a complicated piece.
Easy to replace though.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 09-17-2006, 03:50 AM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Its not the switch - its a $2 spring inside the cancel cam.
The parts store sells the kit for $11 I believe but you only need to replace the two springs inside.
Pull the steering wheel and the lock plate (using a puller) and you will see what I am talking about.
The part they quoted was for the actual switch INSIDE the column not the stalk itself. You can get the stalk for around $45.
What year jeep?
Old 09-18-2006, 01:02 PM
1997 Jeep Cherokee Sport
Old 09-18-2006, 05:52 PM
Well darn - then what I suggested wont work - Im not really familar with the 96 and above XJ's.
Old 09-18-2006, 10:03 PM
AlohaBra's Avatar
AlohaBra AlohaBra is offline
Same thing, different air bag. Disconnect battery before removing air bag and steering wheel.
