Think these will fit?
245x40x18 on a lowerd car? (yah im doubtfull)
Re: Think these will fit?
how low is your car?
Well I know that 275/45/17 fit from a Mustang (not sure what the offset is). They fit just fine in the front with no steering issues, however, in the back the outside of the tires hit the fender just a little when the shocks are compressed (again, might be able to get fixed with a different offset.) I know that these were only 17" wheels, but still.....275's are massively wide tires, and I could not believe that they fit on the car and actually worked (kinda). I too am looking at some 245/40/18 and am a little curious if they will fit with the Eiback Proline drop kit. I think it will be a very tight squeeze, but I have a feeling something can be figured out to make it work. I will find out for sure next spring when I finally get the wheels I want. What I dont understand is that if the car can use an 18x8 wheel, why cant you put the widest tire on it?
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp Last edited by rodbls; 09-16-2006 at 03:32 PM. |
I have 235/45/17 on 17x8 +38 wheels and they don't rub. I'm also lowered with Eibach sportlines. You might be pushing it with a 245 though. Probably would have to cut off those black boxes in the front wheel wells.
I have 225/40R18 and they rub slightly at steering wheel lock to the right.
Got Rota VXR's and Advans for 500 225/45/17
A lot of times the rubbing is surface scratching that sounds worse than it is. More often than not, the tires hit the plastic mud boards/trim in side the wheel-well. Hacking those can give you enough clearence most of the times. Or, you could always have your fenders rolled (doesnt cost that much).
yah its jst rubbing the well, no biggy.
One of my new friends in Florida is running 235/35/19 on his GT and he has no problems. It isnt dropped or anything, and I am not sure of the offset, but it looks pretty good.
2000 Fed. Spec GT-"Lafawnduh" Mods: SPEC 2+ Clutch, Fidanza Flywheel, PowerStop Rotors, Red Stuff Pads, Stainless Brake Lines, B&M Short Shifter, Energy Suspension Shifter Bushings, Deyeme Firm Motor Mounts, KYB AGX shocks with Eibach Proline springs, Halo Projector Headlights with HID 12000K Conversion, TYC Carbon Tails, Kicker SS6.5 Component Front, SS MB8 Custom rear, Tsunami 2F Capacitor, ***New Stuff*** JVC KD-AV7010 In Dash DVD Player, Kicker L7 12" Woofer, Kenwood KAC-X10D Mono Amp |
