Go Back   Automotive Forums Car Chat > Chrysler > Cirrus
Old 09-15-2006, 12:12 PM
marisolp22 marisolp22 is offline
Chrysler ABS Help me PLEase
My Chrysler Cirrus 98 ABS kicks in all the time. Everytime I break the ABS light use to come on but not anymore.Can I turn it off. What is causing this problem?
Re: Chrysler ABS Help me PLEase
[quote=marisolp22]My Chrysler Cirrus 98 ABS kicks in all the time. Everytime I break the ABS light use to come on but not anymore.Can I turn it off. What is causing this problem?
Old 09-19-2006, 08:40 PM
LemansRagtop LemansRagtop is offline
Smile Re: Chrysler ABS Help me PLEase
I had that EXACT problem with my '97 Cirrus. Turned out, one of the wheel sensors had overheated and melted (mine was the left rear). I went to a salvage yard and got another (both rear wheels the same) for $5 .
I also replaced the rear brake hoses and wheel cylinders with a brake overhaul. Reassembled and bled all four wheel until fluid was clear.
Problem solved! BTW, change the auto transfluid REGULARLY with Mopar fluid if you want the trans to last .
Old 09-20-2006, 07:37 AM
I went to Chrysler this weekend. Unfortunately I have to replace the ABS assembly. Part cost 750.00 labor 750.00..I just had the ABS disabled and my brakes redone...And it rides perfectly new...
Old 09-20-2006, 03:46 PM
I'm glad it works right now. I hope it stays fixed for that much green .
Old 09-20-2006, 03:49 PM
***I did not get it fixed I had the ABS disabled for free**
-I only had to pay for the brake pads and new rotors...**
*** If I wanted it repaired it would be approx $1500.00..
