Old 08-30-2002, 01:44 AM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Question Transmission makes funny noises
Just wondering if anyone would have any idea what could be wrong with my transmission. Whenever I start slowing down with the clutch in, the transmission makes a winding down noise. Also with it in neutral and the clutch out, it makes a light grinding noise. Any ideas?
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 08-30-2002, 03:29 AM
91civicDXdude's Avatar
it could be your throw out bearing but its just a guess
Old 08-30-2002, 09:58 AM
red4thgencivic's Avatar
red4thgencivic red4thgencivic is offline
Send a message via AIM to red4thgencivic
It's probably not anything to worry about for now, do you leave your hand on the shifter when it's in gear?
Why can't money come easier?
ok so i had two civic hatchbacks, i totaled one because i wasn't paying attention, the other one i got ran into a creek by an old lady asleep at the wheel, then i got a CRX was being retarded hit a deer at 90 and flipped, so now i drive a 1992 celica GT and i love it, done with being stupid, this one will not be wrecked.
Old 08-30-2002, 10:09 AM
darolh darolh is offline
I'm having a little trouble with yur explanation but I'll give it a try. If it's noisy when you depress the clutch and if the sound changes when you just barely touch the clutch, it's probably the throwout bearing.
With the clutch depressed and it's noisy and no noise with it released an no noise when you just touch it, it's probably the pilot bearing.
If it makes a racket sitting in neutral with your foot off the clutch, and gets quiet with the clutch depressed, it's probably a bearing in the transmission.
Hope this helps.
Old 09-01-2002, 01:02 AM
BullShifter's Avatar
If i'm understanding your noise right, you got the same problem my trans had. NOT a throw-out bearing. It's a main bearing inside the trans. You must replace it. I had replaced main bearings, 2nd/3rd gear sets w/ synchros & did the clutch w/ new throw-out bearing & pressure plate, light-weight flywheel. New axles too. I had a Honda Tech(19 yrs exp) do all the work. Had the trans done in 45 min, then the rest was another 45 mins or so, $50 cash & a case of beer.
I replaced 2nd & 3rd cause they were starting to grind @ high RPM shifts.
If it is your bearing IT WILL get louder.
Old 09-01-2002, 08:58 AM
Tony's Avatar
TLD Member #1
Alright, thanks everyone. I'm going to try to wait and see how long it will last right now, don't have the money to fix it. Going to see if it will last until I can get an engine swap done, but that is still going to be a few years so I might have to get a rebuild kit or something for it.
Tony
Old 09-04-2002, 09:10 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
Actually it might just be normal. The sound it makes with the clutch in slowing down is the clutch matching what the engine rpm will be once you let it out.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
