Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 09-15-2006, 12:33 AM
dreiter dreiter is offline
code 41, intermittent stalling, but cam sensor replaced and magnet confirmed okay
Our 91 Bonneville (192k miles) is throwing a code 41, and is having an intermittent stalling/loss of power problem. I replaced the cam sensor, but the problem continued. Last night with the help of a handy little mirror and my son's help bumping the starter, I was able to confirm that the cam magnet is in its proper position. I am therefore led to believe from previous help on this board that it is probably the crank position sensor. Any further help or thoughts would be greatly appreciated.
Thank you!
Dave
Old 09-17-2006, 08:03 AM
jdl jdl is offline
Re: code 41, intermittent stalling, but cam sensor replaced and magnet confirmed okay
Intermittent problems can be tough to track-down. You need to check for a signal from the cam sensor, while the problem is ongoing.
I believe that is a dual crank sensor, puts out two signals, check those.
My info shows the cam and crank sensors share two circuits. A problem on those circuits could effect both sensors. I don't know if two codes would set?
I'd check those sensor signals before I replaced anything.
Old 09-17-2006, 09:36 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Replacing the crank position sensor should cure your problem. The CPS and CamPS do share circuits so you can get the same code for both. Since you confirmed the CamPS is ok then the crank position sensor would be your next choice.
Old 09-17-2006, 02:11 PM
Bassasasin Bassasasin is offline
I can verify the above post.. THATS What mine did at 180Kmiles
.. CRS sensor replacement $200 @ shop.
Bass
