Old 09-14-2006, 09:06 PM
PlayStation3 PlayStation3 is offline
wiring/ set up question
hi today i was reading my installation manuel for how i should go about wiring up my system and was reading and i found out that i am suppost to just us my rca and not the normal wiring to the amp which will leave my factory wiring useless so i was thinking about using the factory wiring to get 4 22rms tweeter sto put around my 96 sl2 now that will be roughly 6 tweeters in there with 2 compenot speakers, 2 midbass 6.5 subs and 2 12 subs with 3 amps to power them all. now is that to many tweeters to everything else? also i have 3 rca connections. 1 set for sub, one set for the front , and one set for the rear. can i use the rear to power the 6.5 subs?
Old 09-30-2006, 05:07 PM
98gpking 98gpking is offline
Send a message via MSN to 98gpking
Re: wiring/ set up question
what you really should do to make everything SOO much easier is just get a 3 channel amp and a crossover run the subs right off the amp and the mids and tweets through the crossover to limit the power. really you should only have 2 one on each front side of the car unless you have people in the back seats the mids should take care of the rest in the rear.
