Go Back   Automotive Forums Car Chat > Oldsmobile > Bravada
Old 09-14-2006, 07:34 PM
Crys1977 Crys1977 is offline
1997 Bravada problems
Hey everyone, I'm new to the sight. I have a couple things going wrong with my Bravada and was hoping someone could help.
1. My key gets stuck in the ignition when I turn the car off. Have to mess with the shifter or turn the wheel to get it to come all the way back to pull the key out.
2. My car is having issues with not wanting to start. Half the time it will and the other half it wont. It's very irritating. I have had the battery checked and it's a good one. There was some corrosion on one of the battery connecters so I relaced that and it has been starting up for the last couple days with no problems. Today it went to not starting again. Had to hook the jumper cables to it to get it to start.
Was also wondering if these two issues had anything to do with each other.
Thanks for reading and I hope someone can help out.
Old 09-14-2006, 09:03 PM
Chris Stewart's Avatar
Chris Stewart Chris Stewart is offline
AF - Advisor
Re: 1997 Bravada problems
Does the starter engage and turn the motor over or do you just hear a "click"?
Old 09-14-2006, 09:34 PM
I don't hear anything except what sounds like the fan...
Old 09-15-2006, 05:18 PM
AF - Advisor
My battery shows 12.65 volts on a digital voltmeter.
If your battery was leaking acid, it'll keep leaking and needs replacing.
Old 09-15-2006, 06:12 PM
ericn1300's Avatar
ericn1300 ericn1300 is offline
AF Premium User
if it starts when you jump it, and the battery tests good then you have a bad battery connection or something left on that is drawing the battery down.
Old 09-23-2006, 12:53 AM
drdd's Avatar
drdd drdd is offline
have you ever changed your ignition switch ?
Old 09-25-2006, 02:17 PM
no I haven't. Thats something I found out. The ignition switch is going bad. Also, I have a bad spot in my starter...
