Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 09-14-2006, 05:43 PM
eclipsed at 3am eclipsed at 3am is offline
Send a message via MSN to eclipsed at 3am
50 trim setup
ive been hearing about 50 trim turbo setups all over the place, and now im starting to feel like the 16g just isnt good enough now. im thinking of getting into it. if i got the 50 trim, what supporting mods would i need? would i need to change internals, and if so, which internals? would a 2g motor be dumb to put a 50 trim on, because of crank walk? im bouncing between the idea of really hooking my motor up, or getting a 6 bolt and building that up.
beside the turbo itself, would i need a bigger intake and exhaust manifolds? bigger downpipe?? bigger injectors obviously, would a gm maf help? cams?
and last of all...is this all worth it for a fwd?
eclipsed @ 3am
http://www.cardomain.com/ride/2505283
Old 09-14-2006, 06:11 PM
clipse_thumper's Avatar
clipse_thumper clipse_thumper is offline
Send a message via AIM to clipse_thumper
Re: 50 trim setup
wise man once told me that 75% of MODDED 2g's will get crankwalk. it's just a chance we have to take unless you go 1G 6 bolt. i got a question, a guy from DSMTALK said that the 95 2g was the last time they had a 6 bolt. i thought it was 94. i kept telling him but he denied it and said they came with a 6 bolt in a 95 and then they came out with the 7 bolt in 96. am i mistaken? or is this guy an idiot?
Rob Castle
Old 09-14-2006, 06:19 PM
blk_srt's Avatar
blk_srt blk_srt is offline
Send a message via AIM to blk_srt Send a message via MSN to blk_srt
Re: 50 trim setup
6 bolts stopped in 93 or 92 and 7 bolts were from then on
2004 Flame Red SRT-4
|Audiobahn 1200Q|Rockford 602s|Jensen flip out dvd|
Mods:
Old 09-14-2006, 06:22 PM
Re: 50 trim setup
but the 94 eclipse came with a 6 bolt. so they stopped making 6 bolt in 93 but they were still in the 94s, right? i don't know much when it comes to 1g
Rob Castle
Old 09-14-2006, 07:35 PM
crunchymilk55's Avatar
crunchymilk55 crunchymilk55 is offline
Send a message via AIM to crunchymilk55
Re: 50 trim setup
last 6 bolt ever was in 92.5
now - 2000 civic
soon - 2002 is300
Old 09-14-2006, 07:37 PM
Re: 50 trim setup
however I see you're still running 16psi. Before you get the 50 trim I would get the mods needed to run 20-22psi and then see if you still want more power. In my car the difference between 16 and 20psi was literally night / day difference, totally completely different cars.
injectors/dsmlink for now since you are nowhere near maxing the current turbo out.
now - 2000 civic
soon - 2002 is300
