Go Back   Automotive Forums Car Chat > Chrysler > Concorde
Old 09-14-2006, 04:55 PM
heartattack heartattack is offline
overheating sucks!!!!
well I've replaced the thermastat, temp. sensor,and radiator cap but i continue to lose coolant and overheat. Oil isn't frothy. I actually watched the gauge start to drop after a short trip while idling in my driveway. Any help would be welcome.
Old 10-07-2006, 09:18 PM
buckroo buckroo is offline
Re: overheating sucks!!!!
What car and model and year?
Old 10-08-2006, 12:58 AM
94 chrysler concorde
Old 10-08-2006, 09:06 AM
KManiac's Avatar
KManiac KManiac is offline
When you start your car cold, does the temperature gauge slowly rise to full H, then suddenly drop back to normal range, then remain there until the next time you start the car cold?
How many miles on your car?
"This car may be old, but it will still climb Kirker Pass at 110!"
1962 Chrysler 300 2-door hardtop/1964 Chrysler 300-K convertible/1964 Chrysler Newport 4-door sedan/1964 Chrysler 300-K hardtop with Firepower 390/2x1964 Chrysler 300-K hardtop/1964 Chrysler 300 convertible/1964 Chrysler "Silver 300-K" with factory 4-speed/1964 Chrysler New Yorker Salon/1980 Dodge D-50 Sport/1986 Lincoln Continental/1989 Honda Accord DX/1989 Lincoln Mark VII BB/1991 Dodge Shadow ES convertible
Old 10-08-2006, 12:04 PM
no usually it's a case of me drving stopping home and leaving again quickly. there is about 90k on the car.
Old 10-08-2006, 12:36 PM
I am not sure of this year car but some of the later ones have a plastic thermostat housing on the side of the motor (driver side) close to the front that is known to cause leaking of water by cracking. Sometimes this is after the car cools off. Check it out when hot and cold to see if you can see any leaks.
Old 10-12-2006, 12:42 AM
AWP9521 AWP9521 is offline
What's happening sounds like an air lock in the cooling system. There is a bleeder valve on the water outlet neck, make sure the coolant bottle has coolant in it (check it when cold only) then warm up the car and open the bleeder, this will force air out of the system, close the bleeder when coolant starts coning out. Let it run until the fans turn on and open the valve again to purge more air out. btw, your fans are working right?
Originally Posted by AWP9521 - 02/16/2005
Sure sex is a thrill too, but your modified car will never tell you
"Sorry honey, I just don't feel like it tonight" it will always be in
the garage silently waiting for you to hop in so it can thrill you
some more, that is unless you break it. At least they're easier
to repair and get the thrill back than a pissed off girlfriend.
