Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 09-14-2006, 04:28 PM
dodgefan dodgefan is offline
Angry engine growl
i have a 1996 dodge ram 1500 laramie slt with a 5.2L v8. about a week ago after getting the truck inspected and registered after 3 months of it sitting in my driveway, it started to have problems. while still and idling the truck runs fine, but when i take it down the road and put any pressure on the gas the engine emits a very loud growling noise from the throttle assembly, which in turn gives no power. i can push the pedal to the floor and it goes very slow but the growl gets louder.
before all of this, i had recently put a new battery, o2 sensors, and a tranny speed sensor in the truck. which ran fine for a day after. i plugged in a scanner to the computer port and got the code for the Throttle Position Sensor, so, replaced that, still the same thing except now... the check engine light is on, and still i get the TPS code on the scanner. went back and checked the wiring for the sensor and all the voltages are right on the money. i am at a loss as to what the problem may be. was reading some other posts on the forums, could this be a collapsed cat converter? or possibly the idle air controller? not sure why its still giving me the throttle position sensor code on the scanner.
Old 09-14-2006, 08:44 PM
BleedDodge's Avatar
BleedDodge BleedDodge is offline
Send a message via MSN to BleedDodge
Re: engine growl
Yes.
My Mopars
Old 09-15-2006, 12:38 AM
hondahappy86 hondahappy86 is offline
Re: engine growl
yes...definately a cat...it happened to mine too....i hollowed it out and put in new o2 sensors.....it will be fine
Old 09-15-2006, 12:00 PM
Re: engine growl
well, i got some information on the dodgetalk forums that it may be a frozen IAC, so im going to try to clean that up first/buy a new one since its a much easier/cheaper fix. thanks for the replies
Old 09-15-2006, 11:02 PM
BleedDodge's Avatar
Re: engine growl
Those guys don't know anything.
My Mopars
Old 09-16-2006, 07:54 AM
sd03ram1500's Avatar
sd03ram1500 sd03ram1500 is offline
Re: engine growl
IAC shouldn't have anything to do with getting on the gas. like it's called.. IAC - Idle Air Control. it doesn't affect anything above idle. i agree that your Cat is toast. gl
